Re: Integration Of Shoutbox In The All Sections
I think you should be able to do that trought the CMS, just going to each page and adding the block.
Thank you for your response "novice programmer",
I try, but without success.
I would like to integrate it into the top section (once inside) for example, above:
Patches, Documentation And How To, General Support, Bugs, ,Translations ... etc
Best regards
