Post Changing The Home Page
Ok i have a splash screen for my index.php. What is the best way to go about changing the home page to say index1.php (this is what i renamed it for now until i make the site live)... For starters i have already changed the dynamic links with no problem. But like where is the link for the home in the cms and all the others.. Or is there something in the ACP i can change that will make it alot easier.. thank you
www.cisclan.com here is where the splash screen shows up. Right now it still goes to my old site
redrumm101Send private message
Post Re: Changing The Home Page
I gues you are tring to change the URLs for the CMS.
Look at the includes/constants.php file. It includes all the paths.
Ok that worked. The other problem that i ran into is when you create a new page in the cms without using an actual php page for it. It will take you back to the main site which would be a splash screen for me
example  http://www.cisclan.com/index.php?page=3
should be http://www.cisclan.com/index1.php?page=3
thank you very much
