Post Solved - Forum Width Too Wide After 27c Patches
Thanks for the newest patch for 1.2.0.27 (cumulative)
I have 2 small issues since the patch:
The Forum.php width is now too wide.
<SNIP>
Thanks in advance.
http://www.portal.thegtsaga.net/main/forum.php
note: it only happens on MG templates. (with the exception of Aphrodite) Thanks
My main IP 1.3 site
My IP 1.3 styles test site
Edited by Guest, Mon 15 Sep, 2008 09:56: Edit the Title - Snip off-topic question
gearheadSend private messageVisit poster's website
Post Re: Newest Cumulitive Patch Problem
index_body.tpl was the only template file upgraded to .27c.
Find:
height="10" width="900px"
Change: 900px to either 700px (Fixed Width) or 90% for fluid width.
Let us know how it goes.
Your second question has (I think) already been answered here - If not, please post it in a new thread.
Thanks. Hey, I was un-installing templates, and deleted my browser history.
Is there any way to re-set to Icy Phoenix, so I can log in?
That was a silly mistake. I left my computer in a hurry.
thanks.
My main IP 1.3 site
I can see what the problem is from your Url - It has been discussed here, but if you have problems with finding the correct answers, please post a new thread and post the actual error message that the link is showing.
Thanks. I'll do it.
by the way, index_body.tpl was the only template file upgraded to .27c.
Find:
index_body.tpl is not found in the folder you specified: (templates/mg_themes)
oops, I found it. never mind.
It's fixed now!!!! Thanks a million!!!!!!!!!! I used the neat little 'find' feature in my text editing program. I changed the width to 700px.
thanks.
My main IP 1.3 site
gearhead wrote: [View Post]
index_body.tpl is not found in the folder you specified: (templates/mg_themes) oops, I found it. never mind.
Would I lie?
I should have been a bit more specific though, even for the sake of others with the same problem - But I assumed that you, well sort of knew where it was.
Post Re: Solved-Newest Cumulitive Patch Problem
To be honest, I've not had to do anything much to Icy Phoenix. It's just a great CMS.
<SNIP>
note: by the way, for any users here who want to do this: I ended up going with the 100% size tag, because I can get a nice fit even with the menu showing on the forum index!!!!....also fix the marquee tag to around 85% to keep it from starting the scroll from off the side of the forum......!
Thanks a billion.....
My main IP 1.3 site
Edited by Guest, Mon 15 Sep, 2008 09:37: Snip off-topic question.
I've snipped your second question to keep this thread on topic. Can you please post it in a different thread.
Lopalong wrote: [View Post]
10-4 good buddy, I'll try to keep my excitement toned down just a bit and not babble.......he he.
My main IP 1.3 site
