Post PROBLEMS WITH HOSTING
Hello I have my IcyPhoenix in my Own pc and it works fine and now i uploaded everything to a free hosting but I just remember in CONFIGURATION OF SERVER I wrote there my own computer link with no ip
 in this case
Domion Name : gamespor.sytes.net
Scripts Ubication : /gamespor/
I changed the SQL and it works I mean I see my website in the free hosting but when I wanna go to another windows, it just doesnt work it says PAGE NO FOUND so i think i should change those things but I dont find them
I change the config.php   for the USERNAME , password and DATANAME and it works but i dont find how can I change those things
maybe someone nows a solution
or a Free hosting I can use plss thanks
lvliguelSend private message
Post Re: PROBLEMS WITH HOSTING
What exactly are you looking for? What is your site about?
If you're looking for a free, legal site, I'd reccommend byethost
If you need something else (SNIP) I can link you via PM if you would like.
I do have 3 paid hosting accounts active,If you have a fairly small site, I can probably host you.
Edited by Guest, Thu 04 Sep, 2008 09:28: Snipped.
MurderfaceSend private message
no no porn well maybe in the future :p
i am making for GAMES
but i dont know if u understand
how can I move my icyPhoenix which works in my PC to a HOST online????
I changed the configuration in  config.php
anything else?
lvliguel wrote: [View Post]
anything else?
You also need to change the DNS and urls in the database so that they match the site you have uploaded Icy Phoenix to.
Better you do a fresh install on your shared host.
how can I find those configs??? what php??
and how can I upload more AVATARs in my ICYPHOENIX
