Post SOLVED - Usernames Missing After Update From 1.1.0.15
Hi there.
I just updated from 1.1.0.15 to 1.2.0.27.
First time it looked like it went wrong, then this website went offline I thought, well another day tomorrow.
Just when I placed the backup back, icyphoenix.com went up again, so I wanted to give it another try.
Same thing hapened as before, the forum is working fine as far as I can tell, however all usernames are missing (from all blocks/ login info/ last posted/within the posts everywhere)
I cannot go back to the the prvious version since I made a type while backing up
I assume it is something stupid and easy to fix, since I CAN login and see all the users in the backoffice.
any ideas?
[1 hour later......]
OK already found it.
Some way group color went haywire, first I was missing the column u.user_color, so I added it again, after I knew that, I went checking things and found out the groups were there, but had no color configured.
Gonna sleep now thanks!
sstenoSend private message
Post Re: Usernames Missing
So is this fixed / solved or what ?
ssteno wrote: [View Post]
So yup, fixed.
