[SOLVED] How To Hide The Menu Block From Da Forum?
hello. me askin againd.. for the second time.. well i just wanna know.. how to take off the left blocks
or hide then when my users are brwsing the forum.. and to be there when the are in the porta.. tanx
Inactive User
Re: How To Hide The Left Block From Da Forum?
eros,
Do you mean the Menu on the left hand side in the forum ? Because it collapses when you click the minimise icon. ? It can also be removed permanently from the forum window if you want to do that.
Is that what you want to do, remove it permanently ?
The time now is Wed 30 Apr, 2025 13:39 • All times are UTC + 1 Hour [DST enabled]
