Page 1 of 3
Goto page 1, 2, 3  Next
Post [RELEASE] ICY_HEART STYLE
The structure its bluepearl that i have modifed at my vision for my page . And as i promess i will share for who like it . As i am not a designer if you see any bug for any color that i havent see write here .
Theme its for latest icy_phoenix
Theme pic
 style_copy_1206988368_543916
 forum222
 post
ICY_HEART
keanySend private message
Post Re: [RELEASE] ICY_HEART STYLE
Very good style!!!
nice
thanks..i go to try it
great   style ...
now see this...as i haved problem, also u have ...
 red1
and fix is here --> http://www.icyphoenix.com/viewtopic.php?f=2&p=27022#p27022  see reply of Lopalong
one another thing shoutbox is blue ... but this is maybe only to me .. but check it in your site
 red2
Thank u for checking problems ..shoutbox its blu(i know that)  cause of background as i like that blu lines at the sides(but the blu part its not when u write or when you read your mesage ) if any one want the part blu of shout box other color just change background . the other problem i dont see it in my local host or in my page . Sorry if i  havent understand u ..do u see this problem only with opera ?
PS:can u see the first problem at my site www.shqipforum.com
keany wrote: [View Post]
no, becasue you dont have this opened in ACP
Nice keany, Very nice!
If you and limun keep this up, I might stop making themes.
Your Stat's have white text on a white background.
That's all that I could see, and maybe the logo could have some padding on the left-hand side as it looks a little cramped against the shadows.
Lopalong wrote: [View Post]
dont stop , i waiting your Vista like a wolf
With IE7 you have in the Welcome Block -
<td width="3%"><img src="none" alt="" /></td> and it's showing a red X to an image called NONE?
If you have to force some spacing there, try <td width="3%">&nbsp;</td> but there are other ways to do it using the {SPACER} VAR
                                    <table class="roundedtop" width="100%" cellspacing="0" cellpadding="0" border="0"><tr><td align="right" valign="bottom"><img class="topcorners" src="templates/mg_themes/images/p_blue/tbl_h_l.gif" alt="" /></td><td class="roundedhc" width="100%" align="center"><span class="forumlink">Welcome&nbsp;</span></td><td align="left" valign="bottom"><img class="topcorners" src="templates/mg_themes/images/p_blue/tbl_h_r.gif" alt="" /></td></tr></table>                                    <table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
                                        <td class="row1g-left gen">
                                                            <table class="empty-table" width="100%" cellspacing="0" cellpadding="0" border="0">
        <td width="5%"><img src="images/bosh.png" alt="" /></td>
        <td width="100%"><img src="images/sfidoj2.png" alt="" /></td>
</table>
Perharps you want to contact MG to insert it into the downloads section.
Administrators are the unique users allowed to to so.
sjoud we contact him , when we relase something ..theme ...?
where , how
Keany, you may want to address these issues:
Rename:
style_p_blue.css to style_icy_heart
overall_header_bl.tpl to overall_header_icy_heart.tpl
overall_footer_bl.tpl to overall_footer_icy_heart.tpl
images/p_blue to images/icy_heart
And adjust the red_theme.cfg, theme_info.cfg and paths in the .css to suit.
Then remove all of the unwanted overhead (.tpl files) from the theme, and the surplus array strings from the red_theme.cfg.
Edit: A few more issues.
.css path error
    background: #FFFFFF url(images/m_blue/bg_quote_header.gif) top left no-repeat
Your:
bg_hdr.gif is 966px wide.
bg_nav1.gif is 950px wide.
It not good practice to use such images to accommodate the appearance of the style, you should be using the .css to do that and using images of much lesser width.
Filename: Untitled 4.png
Filesize: 84.15 KB
Downloaded: 242 Time(s)
Thanks lopalong .. As i have said before that i am not a designer ...and its normally that must be any error in style that i have not checked . Perhaps you can help me in some issues . To resolve them in good way . Normally if you have time
Uninstall the Theme.!
DO NOT DELETE: overall_include.tpl
DELETE ALL OTHER: overall_*.tpl files
DELETE:
style_p_blue.css
style_p_black.css
red_theme.cfg
red_theme_old.cfg
theme_info.cfg
Rename:
common.css to "aa common.css" because I don't know if you want to change the buttons or remove the mouse-hover.
The folder - p_blue to icy_heart
Copy the files in the files.zip to /images/icy_heart/ and re-install the theme.
This will make it its "Own" theme and fix the button problem, after that you can decide what you want to do, and how much help you need.
files.zip
Filename: files.zip
Filesize: 18.33 KB
Downloaded: 226 Time(s)
THEME ICY_HEART REFRESHED
PROBLEM WITH OPERA  RESOLVED
PROBLEM WITH STATISTICS  RESOLVED
THANKS TO LOPALONG
PROBLEM WITH NAME  RESOLVED
PROBLEM WITH BUTTONS  RESOLVED
PROBLEM "ANNUNCE" BUTTON  RESOLVED
BG_HDR   RESIZED
BG_NAV1 I THINK ITS NOT PROBLEM AT ALL (THE RED PART DISSAPEAR WHEN YOU OPEN MENU AND APAIR WHEN YOU CLOSE
AGAIN THANKS LOPALONG
PS: Copy the files in the files.zip to /images/icy_heart/ and re-install the theme.  (IS THIS YOU ISSUE          JOKE )
