Post Spacer Bbcode
Hi
Is mod possible to add to icy... I have spent some time looking at the code but cannot find anything similar in the files....
thank you for any help...
Post Re: Spacer Bbcode
ok after spending a few hours studying  bbcode parsing and through trial and error I have managed to get part of this to work....
Basically to enable to add spaces between words using [spacer] bbcode.... I have not managed to get the extra part working as yet whee a user can add a number up to 100 for the amount of spaces they require...
well this is the first bit if there are any errors please let me know....
This does not come with an image you have to type the bbcode into the text box...
OPEN includes/bbcode.php
    var $self_closing_tags
INLINE FIND
'[url=docs/readme_english.html#license]Readme[/url]',
INLINE AFTER ADD
'[spacer]',
            'ipstaff' => array(
                    'nested' => true,
                    'inurl' => true,
                    'allow_empty' => true,
AFTER ADD
            'spacer' => array(
                    'nested' => true,
                    'inurl' => true,
        // Easter Eggs - START
        // Single tags: xs or ipstaff
        if( ($tag === 'xs') || ($tag === 'ipstaff') )
            $html = $lang['BBC_IP_Credits'];
            return array(
                'valid' => true,
                'html' => $html
BEFORE ADD
                if($tag == 'spacer')
            $html = ' ';
                    return array(
                'valid' => true,
                'html' => $html
            $tag_ok = false;
            if( ($tag === '*') || ($tag === '[*]') || ($tag === '[hr]') || ($tag === '[url=docs/readme_english.html#license]Readme[/url]') || ($tag === '[url=docs/readme_english.html#license]Readme[/url]') || ($tag === '[url=docs/readme_english.html#license]Readme[/url]') || ($tag === '[url=docs/readme_english.html#overview]Readme[/url]') || ($tag === '[url=docs/readme_english.html#license]Readme[/url]') || ($tag === '[url=docs/readme_english.html#requirements]Readme[/url]') || ($tag === '[url=docs/readme_english.html#fresh_installation]Readme[/url]') || ($tag === '[url=docs/readme_english.html#upgrade_phpbb]Readme[/url]') || ($tag === '[url=docs/readme_english.html#upgrade_phpbb]Readme[/url]') || ($tag === '[url=docs/readme_english.html#upgrade_xs]Readme[/url]') || ($tag === '[url=docs/readme_english.html#upgrade_ip]Readme[/url]') )
INLINE FIND
INLINE AFTER ADD
($tag === '[spacer]') ||
Thats it
if you need to add extra spaces just use [spacer]
if anyone could help with the other part I will be very grateful...
Thanks DWho, this MODification working in IP 1.2.0.27?
Greets
DWho wrote: [View Post]
            $html = ' ';
                    return array(
                'valid' => true,
                'html' => $html
Replace this code with:
        // SPACER
        if($tag === 'spacer')
            $html = '';
            if(isset($item['params']['param']))
                for ($i=0; ($i < intval($item['params']['param'])); $i++)
                    $html .= '&nbsp;';
            else
                $html = '&nbsp;';
            return array(
                'valid' => true,
                'html' => $html
It seems it is a bug and you can't set [spacer=5] or [hr=#FF0000] (the second one should be working)...
This code I've posted will not work until the bug is fixed.
Greets!
Gabriel Anca
KasLimonSend private messageVisit poster's website
Hi
So as soon as the bug is fixed it should work as discribed?  Does that mean you can add a number after space=? and that many spaces will appear in the text box...?
thanks for looking and correctly correcting my code....
Yes, nut only if the bug is corrected.
Greetings
Gabriel Anca
Excellant....
So how do we fix the bug or is that for the main developers of the site to look at..?
Do I need to post a bug report..?
I've already reported the bug, but we have to wait until Luca reads it
Gabriel Anca
ok cool
Thank you
