Page 1 of 3
Goto page 1, 2, 3  Next
Post You Have Exceeded The Number Of Registration Attempts
I have the same problem now! I've read the complete topic http://www.icyphoenix.com/viewtopic.php?p=16629 and nothing worked!
In my site is working under an ISA SERVER and all user posts seems to come from the same IP
How can i solve this please?
Settings in CrackerTracker for Register Protection system is all "Disabled". I disabled most of point in here, some days it worked for 30 minutes but on next day it happened again!
Try to register in my site: http://www.miviajeaeuropa.com.ar/forum please!
ialvarezSend private messageVisit poster's website
Post Re: You Have Exceeded The Number Of Registration Attempts
I have the same problem. I don't found solution. My temporal solution is to put a menssage to contact me if an user have this problem.
Webmaster: EliteMoviles
Server: Sotem.es
Version: Icy Phoenix 1.2.0.27
AexoSend private messageVisit poster's website
Please, report us the version of icy you use.
In the ACP my Site says... "Powered by Icy Phoenix 1.0.14.14 based on phpBB 2.0.22"
But I download the last version last week called "ip_20071031_11015_cumpatches". Why does my site not change the version to the last one?
Thanx
Post Re: BUG - You Have Exceeded The Number Of Registration Attem
My site is the last one: 15c. I actuallizated from XS and I always have this problem
Server: Sotem.es
MG are you there man?    Help us please!
Be patient
Server: Sotem.es
maybe here [don't remember]
try to increase this number
includes/usercp_register.php
find
if ($row['attempts'] > 3)
                message_die(GENERAL_MESSAGE, $lang['Too_many_registers']);
*VOLVO CLUB*
ialvarez wrote: [View Post]
Thanx
Because the cumpathes are for people who has got that version before.
You should upgrade to 1.1.0.15c before apply any cumulative patch.
Thanx
I agree with novice
the version is written in database
*VOLVO CLUB*
Sorry for so a stupid question but how I update my site from 1.0.14.14 to 1.1.0.15c ?
I went to DONWLOAD here and found the file! After download it I copied everything over the site root and then the site tried to install everything from begining asking me server, user, etc.
Is that the correct way? Is there a TOPIC here teaching how to update IP to new versions?
2ยบ question... I have my site working in a public domain like everyone here. I would like to have a copy of it workin in my computer localy.
First i copied all the files and then i went to the DATA directory and copy my MySQL database from a computer to other.
The site seems to work but when I enter to any TOPIC y show me error 404.
I know I can backup my datebases from ACP, it generate a file and then when I try to restore it on the other site I get almost a blank page. You can see it here!
Filename: Restore.JPG
Filesize: 64.27 KB
Downloaded: 186 Time(s)
Filename: Restore2.JPG
Filesize: 50.73 KB
Downloaded: 189 Time(s)
remember
you are not installing new site, you are updating !
replace root without config.php and install dir.
in install directory find update_to_ip.php file and place into root too
login as admin and run it www.yoursite/icyphoenix/update_to_ip.php
*VOLVO CLUB*
second question
do you change server and path in database config table ?
*VOLVO CLUB*
Thanx Difus for help!
1) I will do it now and tell you later if worked!
2) I did not understand the question. Will you tell me the steps to backup a database y restore it later on a diferent Server?
I did the following:
    - First I went to ACP on Icyphoenix and backup DB. (I got a file there)
    - Second I went to my clon site to ACP and try to restore it without doing anything else and I got the screen you could see in my post before.
Is there a step I have to do before Restoring?
P/D: My production site is working on http://150.150.1.75:8090/forum (internal IP) and MySQL DB is in 150.150.1.75
and my Backup site is on a different address: http://150.150.1.22:8090/forum and the MySQL DB is in 150.150.1.22
In both cases DB have the same name (foro)
Point 1 solved! Thanx man!
Let's go for the point 2)
