Post Black Pearl Skin Question?
is there a chance to get, download the revisted version of this template which is fit for the newest phpbb RC 7
version?
Cause the older version works just with RC5!
Thank you in advance for the answer!
DrZoidbergSend private message
Post Re: Black Pearl Skin Question?
Style updated.
Style updated.
damn you faster than the fireman, really thank you a bunch for this unique style
Kind regards from germany
DrZoidberg wrote: [View Post]
Style updated.
You're welcome, please let me know if you encounter some bugs over the way.
Style updated.
will do this !
Is there a list of changes that Black Pearl had with RC7..  I am burnt out from looking at code from changing some of our graphics and stuff over and dont really wish for a redue of the whole theme.  What lines and stuff were changed also, if there is a script file would be nice!!! :PP I know im bugging  but it would be much appreciated.
Thanks!
SAbramsonSend private message
You can check the changes with WinMerge. It is a freeware program that can check the difference between the new and old files!
SAbramson wrote: [View Post]
Thanks!
You can use the subSilver 2 code changes, because this template is based on subSilver 2. I guess you should find almost everything.
Code Changes for subSilver 2 may be found @ phpbb.com.
