Post Saturated Server
Hi!
My host have suspend my icy phoenix because they say my page "saturate the server", and they give me this log:
I use a payed host! ($$)
I am from argentina and not speak very well english :$
My site is:
www.durisimatv.com.ar
| 1489043 | od000060         | localhost | od000060_Durisimatv | Sleep   | 179  |                |        |
| 1489046 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489047 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489049 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489050 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489051 | od000060         | localhost | od000060_Durisimatv | Sleep   | 229  |                |        |
| 1489052 | od000060         | localhost | od000060_Durisimatv | Sleep   | 229  |                |        |
| 1489053 | od000060         | localhost | od000060_Durisimatv | Query   | 51   | Opening tables | UPDATE ip_config
| 1489054 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489055 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489056 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489057 | od000060         | localhost | od000060_Durisimatv | Sleep   | 206  |                |        |
| 1489058 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489059 | od000060         | localhost | od000060_Durisimatv | Sleep   | 221  |                |        |
| 1489060 | od000060         | localhost | od000060_Durisimatv | Sleep   | 227  |                |        |
| 1489062 | od000060         | localhost | od000060_Durisimatv | Sleep   | 227  |                |        |
| 1489063 | od000060         | localhost | od000060_Durisimatv | Sleep   | 227  |                |        |
| 1489064 | od000060         | localhost | od000060_Durisimatv | Sleep   | 194  |                |        |
| 1489065 | od000060         | localhost | od000060_Durisimatv | Sleep   | 190  |                |        |
| 1489066 | od000060         | localhost | od000060_Durisimatv | Sleep   | 193  |                |        |
| 1489067 | od000060         | localhost | od000060_Durisimatv | Sleep   | 190  |                |        |
| 1489068 | od000060         | localhost | od000060_Durisimatv | Sleep   | 194  |                |        |
| 1489069 | od000060         | localhost | od000060_Durisimatv | Query   | 36   |                |        |
| 1489071 | od000060         | localhost | od000060_Durisimatv | Query   | 76   | Opening tables | SELECT u.*, s.*
| 1489075 | od000060         | localhost | od000060_Durisimatv | Sleep   | 179  |                |        |
| 1489078 | od000060         | localhost | od000060_Durisimatv | Query   | 94   |                | SELECT u.*, s.*
| 1489079 | od000060         | localhost | od000060_Durisimatv | Sleep   | 190  |                |        |
I dont know what happend:(.. its the normal functionality of icy?¿ it use a lot of resourses?¿
HELP:(
yamyamSend private message
Post Re: Saturated Server
that was a log of the sql queries.
For giving more help, you´ll have to give more data, as the bandwith and space, server.....
i have check that
My host is DATTATEC (Argentina)
Is in LINUX
Is not a problem of bandwith or space because:
Bandwith use:  4.49 %  (3595.55 / 80000.00)
Space use:  0.01 %
its a sql queries problem...
THIS IS MY PLAN:
http://www.dattatec.com/sp/planes_detalle.php?idprod=1
HElp:(
You need to disable most of the features, so you can use it at low charge.
Disable even similar topics and image thumbnails which under certain circumstances load CPU so much...
Try to look in Docs section for other tips on how to reduce SQL and CPU charge.
Dattatec isn't a good host, they do "overselling" and because that you just can host there small sites with small CPU use.
Could you give us more stats about your site?
AMateosSend private message
What stats need?
Users: 2000
mmm diary visits: 1000
a lot of forumsç
WHAT HOSTING RECOMEND ?¿
I think a normal hosting can host you without problems. I have clients with that stadistics and more without problems.
Try searching on: www.buscahost.com and come back here to ask about your candidates
i use www.elserver.com
runs fine in argentina
