Re: I Got Problems With The ADmin Account And Seeing The ACP
ok were to start on god here we go.
1. di all this try to clear cache folder , optimize database did not work.
2.go to sql > phpbb_users see your ID
ok found my user name and password
to make sure that sql was storeing the right password
i check the password via a hash claculator it check out viald hash in mysql
even tried to make a new one and input into the mysql still did not work
http://www.dark-asylum.co.uk/fourm_/index.php
you will see at the top of the page
The time now is <37eWednesdayec30 9pm09e= | All times are UTC
you see this is not right i sure it the old phpbbs template that is doing this
i take it i can still use old phpbb templates ???, i sure this is why i been locked out the
ACP
i also had problems with making new fourms in the
ACP pannel before i got locked out
any help on this would be great . as realy want to use the template??
