Post Error To Install Morpheus IP
Hi everybody!
I dont know if I make a mistake trying to install Morpheus IP template... I follow this:
1. Upload all the files descompresed to templates/MG themes/
2. ACP, Extreme Styles, Install Styles... and I cant see the style to install...
and, this messages appear up in the install option:
privmsg'] = '0'; ?>mg_themes[1]['img_size_poll'] = '0'; $mg_themes[1]['img_size_privmsg'] = '0'; $mg_themes[0]['template_name'] = 'mg_themes'; $mg_themes[0]['style_name'] = 'Morpheus IP'; $mg_themes[0]['head_stylesheet'] = 'style_m_blue.css'; $mg_themes[0]['body_background'] = 'm_blue'; $mg_themes[0]['body_bgcolor'] = ''; $mg_themes[0]['body_text'] = ''; $mg_themes[0]['body_link'] = ''; $mg_themes[0]['body_vlink'] = ''; $mg_themes[0]['body_alink'] = ''; $mg_themes[0]['body_hlink'] = ''; $mg_themes[0]['tr_color1'] = ''; $mg_themes[0]['tr_color2'] = ''; $mg_themes[0]['tr_color3'] = ''; $mg_themes[0]['tr_class1'] = ''; $mg_themes[0]['tr_class2'] = ''; $mg_themes[0]['tr_class3'] = ''; $mg_themes[0]['th_color1'] = ''; $mg_themes[0]['th_color2'] = ''; $mg_themes[0]['th_color3'] = ''; $mg_themes[0]['th_class1'] = ''; $mg_themes[0]['th_class2'] = ''; $mg_themes[0]['th_class3'] = ''; $mg_themes[0]['td_color1'] = ''; $mg_themes[0]['td_color2'] = ''; $mg_themes[0]['td_color3'] = ''; $mg_themes[0]['td_class1'] = 'row1'; $mg_themes[0]['td_class2'] = 'row2'; $mg_themes[0]['td_class3'] = ''; $mg_themes[0]['fontface1'] = ''; $mg_themes[0]['fontface2'] = ''; $mg_themes[0]['fontface3'] = ''; $mg_themes[0]['fontsize1'] = '10'; $mg_themes[0]['fontsize2'] = '11'; $mg_themes[0]['fontsize3'] = '12'; $mg_themes[0]['fontcolor1'] = ''; $mg_themes[0]['fontcolor2'] = '22BB33'; $mg_themes[0]['fontcolor3'] = 'DD2222'; $mg_themes[0]['span_class1'] = ''; $mg_themes[0]['span_class2'] = ''; $mg_themes[0]['span_class3'] = ''; $mg_themes[0]['img_size_poll'] = '0'; $mg_themes[0]['img_size_privmsg'] = '0'; $mg_themes[1]['template_name'] = 'mg_themes'; $mg_themes[1]['style_name'] = 'Morpheus IP Green'; $mg_themes[1]['head_stylesheet'] = 'style_m_green.css'; $mg_themes[1]['body_background'] = 'm_green'; $mg_themes[1]['body_bgcolor'] = ''; $mg_themes[1]['body_text'] = ''; $mg_themes[1]['body_link'] = ''; $mg_themes[1]['body_vlink'] = ''; $mg_themes[1]['body_alink'] = ''; $mg_themes[1]['body_hlink'] = ''; $mg_themes[1]['tr_color1'] = ''; $mg_themes[1]['tr_color2'] = ''; $mg_themes[1]['tr_color3'] = ''; $mg_themes[1]['tr_class1'] = ''; $mg_themes[1]['tr_class2'] = ''; $mg_themes[1]['tr_class3'] = ''; $mg_themes[1]['th_color1'] = ''; $mg_themes[1]['th_color2'] = ''; $mg_themes[1]['th_color3'] = ''; $mg_themes[1]['th_class1'] = ''; $mg_themes[1]['th_class2'] = ''; $mg_themes[1]['th_class3'] = ''; $mg_themes[1]['td_color1'] = ''; $mg_themes[1]['td_color2'] = ''; $mg_themes[1]['td_color3'] = ''; $mg_themes[1]['td_class1'] = 'row1'; $mg_themes[1]['td_class2'] = 'row2'; $mg_themes[1]['td_class3'] = ''; $mg_themes[1]['fontface1'] = ''; $mg_themes[1]['fontface2'] = ''; $mg_themes[1]['fontface3'] = ''; $mg_themes[1]['fontsize1'] = '10'; $mg_themes[1]['fontsize2'] = '11'; $mg_themes[1]['fontsize3'] = '12'; $mg_themes[1]['fontcolor1'] = ''; $mg_themes[1]['fontcolor2'] = '22BB33'; $mg_themes[1]['fontcolor3'] = 'DD2222'; $mg_themes[1]['span_class1'] = ''; $mg_themes[1]['span_class2'] = ''; $mg_themes[1]['span_class3'] = ''; $mg_themes[1]['img_size_poll'] = '0'; $mg_themes[1]['img_size_privmsg'] = '0'; //-- mod : post icon ------------------------------------------------------------------------------- //-- add $images['spacer'] = "$current_template_images/spacer.gif"; //-- fin mod : post icon --------------------------------------------------------------------------- ?>
What is my mistake? What can I do?
Thanks a lot for support me..
by the way, my url is www.sermonesadventistas.org, is a update from phpbb2 and I install this forum in a paid hosting.
MairenaSend private message
Post Re: Error To Install Morpheus IP
Well... I change the theme_info.cfg and the messages dont appear now...
But, I canĀ“t install Morpheus I delete the chache files (in ftp), erase the internet temporary files, and.. nothing happen!!
What I did wrong?
Help me...
I guess you should try to reupload the original cfg again.
Maybe it was corrupted.
Try to manually check your themes table to see if there is a corrupted Morpheus installation and manually delete that row.
Can you guide me to check my themes table?? I dont know how to do it...
Thanks a lot for support...
Export your phpbb_themes table, and post it here in a zip file.
ok....
Thanks.. here is the file....
mairenaa_phpb1.sql.zip
Description: Here the export file in sql format...
Filename: mairenaa_phpb1.sql.zip
Filesize: 964 Bytes
Downloaded: 205 Time(s)
In the file you attached there's no reference to Morpheus, you can try to reinstall it.
~~~ Andrea ~~~
User #379756 on Linux Counter
