Post SOLVED - Problems
I get this error, dont know how to fix it,  PLEASE HELP
Critical Error!
message_die() was called multiple times.
 Error #1
Line : 60
File : /fpgs/fpgshttpd/sclicks/superjuegos3/ctracker/classes/class_ct_database.php
SQL : SELECT * FROM sj_ctracker_config
  Error #2
Could not get theme data for themes_id []
Line : 809
File : /fpgs/fpgshttpd/sclicks/superjuegos3/includes/functions.php
  Please, contact the webmaster. Thank you.
rocoSend private message
Post Re: Hacked?
First of all you are not hacked, so edit the title of your post... the error is from your board security Cracker Tracker.
second make sure you have installed any new themes correctly.
jzSend private message
Post Re: Hacked?
jz wrote: [View Post]
It was working ok,  i have not installed or changed any config in the last 15 days.
EDIT: never mind,  problem was that server was hacked, not my page in particular.
Loading...
