058-004 - FIXED - Security Fixes
Hi all.
This patch is meant for fixing some potential security risks on your XS.
Apply this patch as soon as possible by replacing all files.
This patch also include a new META KEYWORDS insertion on your pages. You can customize page_header.php to insert your informations.
Thanks to Antonio Mercurio for the help with META TAGS.
IMPORTANT: by applying this patch, if you have thumbnails in posts enabled, you won't be able to see the thumbnails of files which are not JPG, GIF or PNG. I had to insert this because of security issues still to be fully verified.
Description: |
058-004 - Security And RSS Fixes |
Download |
Filename: |
058_004_Security_RSS_Fixes.zip |
Filesize: |
51.93 KB |
Downloaded: |
814 Time(s) |
Edited by Mighty Gorgon, Sun 27 Aug, 2006 14:39: Patch files updated |
#1 Sun 27 Aug, 2006 03:46 |
Miguel
Respuesta: 058-004 - FIXED - Security Fixes
thx man, nothin' is perfect, you're makin' a great work
____________ Life's a bitch and then you die, that's why we get high,
Cause you never know when you're gonna go.
#2 Sun 27 Aug, 2006 04:46 |
Re: 058-004 - FIXED - Security Fixes
Unfortunately you're right... nothing is perfect!
I hope that this fix will definitely solve the security issues of phpBB XS.
#3 Sun 27 Aug, 2006 04:49 |
Miguel
I hope so...
#4 Sun 27 Aug, 2006 04:55 |
ThE KuKa
Thanks MG, and welcome to home
#5 Sun 27 Aug, 2006 05:07 |
Thanks ThE KuKa!
#6 Sun 27 Aug, 2006 05:31 |
m740
____________ www.todoPVR.com IP 2.0.0.86 DVB-T PVR's
#7 Sun 27 Aug, 2006 07:25 |
difus
Thanks. Going to apply to my releases
#8 Sun 27 Aug, 2006 09:38 |
KugeLSichA
code removed because MG did some changes and this post was not up to date
#9 Sun 27 Aug, 2006 11:41 |
difus
what are the mods ?
#10 Sun 27 Aug, 2006 11:46 |
Gary
Is this risk in the older versions as I am not going to update to the 058 version as there are to many mods.
If there is a risk in the older version what is the fix for the 049 version?
#11 Sun 27 Aug, 2006 11:48 |
KugeLSichA
what are the mods ?
Download MOD. (not pafile DB) try to edit one download and watch the download title
#12 Sun 27 Aug, 2006 11:55 |
difus
yes it is adding phpBB XS
thanks
#13 Sun 27 Aug, 2006 12:03 |
carlos
#14 Sun 27 Aug, 2006 12:26 |
jz
Thank you Mighty
#15 Sun 27 Aug, 2006 13:02 |
