Post Missing Forums In My Upgraded XS2
Hello there,
I have a strange problem after upgrading my (local) copy of XS2 0.58 with Icy Phoenix.
I followed all the instructions, updated the db and applied patch 001.
Everything seems to work fine, but when loading the forum index all my previously forums are not available.
See the attached picture to see what appears, instead.
Thanks in advance for any suggestion.
Bye.
Filename: no_forum.jpg
Filesize: 103.89 KB
Downloaded: 606 Time(s)
magmaSend private message
Post Re: Missing Forums In My Upgraded XS2
Try to resync forums
Have you tried to upload the def_tree.php file from installcontribcleanincludes?
Off Topic
P.S.: just a little question: how did you change the main font of your forum?
Zuker wrote: [View Post]
It's the first thing I tried before posting, but it doesn't work.
The weird thing is that if I load, in ACP, the "permissions list" (the expanded one, I mean) I see all my forums.
Any other tip?
I've nearly 50.000 post in my DB, not a "Test Category" and a "Test Forum"... I'd like to recover all the previous structure!
TIA and bye.
andrea75 wrote: [View Post]
Off Topic
No... I try it now, thanks!
For the OT I don't understand... do you mean HTML/CSS?
Try to upload an old backup of your def____ files
magma wrote: [View Post]
Off Topic
No, I mean type of carachter. From the snap, seems that the font used is Tahoma (or similar), instead the default.
Yes, is better a copy of backup if he has got them, but usually the upload of a clean file work fine anyway.
Deleted the old def_tree.php file and solved! Thanks a lot!
p.s.: for Andrea75: I'm on Firefox on Macintosh, maybe the preferred font list is different from the one on your browser.
Great it's solved
Cya
