Post Quick Question About Changing Db Server
I have to move my database to a different database server. It is enough to change infos in config.php and config_xs.php, right?
Post Re: Quick Question About Changing Db Server
Yes, you must changes the files what you have said no more
Just wanted to be sure...
Thanks a lot
Uhm...
Critical Error
Error: Seek Help
DEBUG MODE
SQL Error : 1048 Column 'login_id' cannot be null
INSERT INTO phpbb_logins (login_id, login_userid, login_ip, login_user_agent, login_time) VALUES (NULL, -1, '97254ab6', 'Mozilla/5.0 (Windows; U; Windows NT 5.1; it; rv:1.8.0.9) Gecko/20061206 Firefox/1.5.0.9', 1170160267)
Line : 227
File : sessions.php
How could this be related to? I imported the new database, than changed config e and config_xs ...
If you are moving only the DB you have to change only config.php... nothing else.
The error is not related to config... try to empty sessions table.
Ok, clearing sessions table wasn't necessary... it was a corrupted backup
Can you please explain to me why it is not necessary to change config_xs.php? I don't understand... I changed db address, doesn't it become useless if don't don't update it?
Vortex wrote: [View Post]
config_xs.php is not part of XS... I don't know why you have that file...
Ah... interesting
Well, thanks for help anyway
