SOLVED How Can I Get The Default Style Displays When I Open The Forum?
Subject: How Can I Get The Default Style Displays When I Open The Forum?
Because for three times my forum shows other stykle (I think BW Phoenix) when just open the forum after my tablet was off. My default style is green vision, modified with my own colors and images.
0126710275
Is there a way that the default theme is displayed when the forum is first opened?
Subject: Re: How Can I Get The Default Style Displays When I Open The Forum?
This problem still happening :|
Did you try the theme picker? The CMS tries to remember which theme you last used.
Informpro wrote: [View Post]
What is "the theme picker"?
I've marked the default styke this way:
estilo_defecto
What else do I have to do?
The theme picker is the one in the menu when you're browsing the forum, on the left usually.
Oh, I got it... Well, the theme picker shows "Green Vision" at the moment to open the forum, but the forum shows the BW Style... Actually, when I pick "Green Vision" nothing happen. I have to change to any other style, and then pick "Green Vision" to the forum displays this default style. It's really weird...
Hi, good morning all :mryellow:
I've just installed other forum named juventudacumulada.net and setting the prosilver IP blue as the default style.
But there is the same problem than my other forum: even when I uninstalled frozen phoenix previous default style, it shows when the forum is open.
The prosilver IP Blue style is the only style installed, as you can see:
por_defecto_1
So, how can I configure my both forums?
Is this a cache issue maybe? If a theme is uninstalled it cannot show at all after that unless it is cached. Recall I had the same cache issue as well on several areas of the portal too.
I have a very fresh install of IP. I will go grab a couple themes and install them and try this out.
**EDIT**
When your website puts it back to the original template, does it take you to the Green Vision after you login to the site?
I went and installed green vision on my website. I then set it as Default style and switched everyone to that style. I then went up top of the ACP and clicked Clear Cache and clicked the first button on that page. I then went and viewed many pages of my website and all was set to Green Vision. All was well. I then went in and shut off my browser and went and got a drink and snack. I came back and started my browser, went to my website and even logged out it was still Green Vision.
Now I was curious and I then went to my browser and cleared all cache and cookies and closed browser again for 2 or 3 minutes. I came back to my website and it was still Green Vision. I can not replicate your issue. I am sorry I can't be of any more help.
On a side note, I set my default style to Green Vision here at IcyPhoenix and every time I log out, I go back to the Frozen Phoenix style until I log back in to the website, then it goes back to Green Vision.
It worked :mryellow: Thank you very much!
Subject: Re: SOLVED How Can I Get The Default Style Displays When I Open The Forum?
Cristianita wrote: [View Post]
That's fantastic! I am glad it worked for you. :mryellow:
Generation Time: 0.801s (PHP: 2% SQL: 98%)
SQL queries: 17 - Debug Off - GZIP Enabled
