SOLVED The Search Appears With Text-align: Left And Some Forums Have Different Width Than Others In Vista Pink Style
Subject: The Search Appears With Text-align: Left And Some Forums Have Different Width Than Others In Vista Pink Style
Hi, God bless you!!
I was all day trying to edit the Vista Pink Style, but I noticed that Search Parent Block text appears on the left, instead of on the center.
Besides, two forums are wider than the rest of forums. I'll show you:
3294465486
7443338107
I uninstalled the style trying to fix it, thinking that I made a mistake; but still the problem.
Could you find the source of the problem?
My forum is
Subject: Re: The Search Appears With Text-align: Left And Some Forums Have Different Width Than Others In Vista Pink Style
Well, this problem seems to be of this specific style. So this problem is solved, because I changed my default style :mryellow: Thanks!
Generation Time: 0.9677s (PHP: 2% SQL: 98%)
SQL queries: 17 - Debug Off - GZIP Enabled
