Magic Quotes And Add/strip Slashes To Be Deprecated
Subject: Magic Quotes And Add/strip Slashes To Be Deprecated
mort wrote: [View Post]
I believe your biggest problem is paths? :(
This is your url:
http://thenortherntundra.com/viewtopic.php?f=3&t=1
Icy Phoenix is/was not designed to run in the root of your domain, although it can be made to do so.
Can I suggest that you remove all Icy Phoenix stuff from the root of your domain and create a folder "forum" (Or whatever you wish it to be) and upload all of Icy Phoenix to that folder and install it from there; so that you end up with something like this.
http://thenortherntundra.com/MyFolderName/viewtopic.php?f=3&t=1
It's the simplest way of avoiding all other problems in the future, when it comes to path issues - And in particular - .htaccess issues. ;)
I thought that un-commenting this line from the .htaccess file was the only thing you needed to do when installing on root.
ea.
RewriteEngine On
#This may cause issues with subdirs and so it is not enabled by default.
#RewriteBase /
becomes,
RewriteEngine On
RewriteBase /
on a root directory install?
My forum is installed in the root dir. :?
Subject: Re: Images In Posts
I could point out some problems with having Icy htaccess in the root - But it's a bit pointless, as the last experience I had was with v27c (I think) ;)
So no doubt I shall not be attempting to provide any other support in future because I have not been keeping up what's happened to Icy Phoenix since then - So it's time to move on again. :P
And what I mean by time to move on again - Counting both of my handles here, my total accumulative posts to date are 2,188 as I was trying to knock MG from the top spot and failed miserably. :LOL:
Time for someone else to give it a try - But I guess it will never happen! :mrgreen:
hm. do you have magic_quotes_gpc on ??
as i see the Flags comented, but i´m not shure, since i don´t understand .htaccess files and rules very well.
anyway , this option should be on by default.
BTW there was a setting in ACP. images in posts, Upload should be set to ALL or Reg
and precompiled posts should be set OFF
I'm pretty sure Icy checks the status of magic_quotes_gpc before it adds slashes or not to prevent double-slashes etc.
And as I understand it magic_quotes_gpc wont exist in phpv6 and addslashes and stripslashes are to be deprecated and replaced with mysql_real_escape_string()
addslashes escapes: ', ", \, and NUL
mysql_real_escape_string escapes, in addition: \x00, \n, \r, and \x1a.
Edit:
And as for checking Magic Quotes etc, it should look something like this.
stripslashes or addslashes
// escape variables
function escape($val){
$val = trim($val);
if(get_magic_quotes_gpc()) {
$val = stripslashes($val);
return mysql_real_escape_string($val);
Or just turn them off altogether in Icy Script. ;)
If anyone would like me to split this topic just shout a new title and a location to put it, cause I think we're drifting away from devildog's support question IMHO :LOL:
Read about this on google - - - Going to mean a lot of work for some people. :mryellow:
Cut it here Josh! :mryellow:
http://www.icyphoenix.com/viewtopic.php?p=54848#p54848
Subject: Re: Magic Quotes And Add/strip Slashes To Be Deprecated
I hope this is how you meant it Mort ... :wink:
LOL
I am lost. I should add little more info though.
The IcyPhoneix version I have installed in the root folder of my TLD is 1.3.0.53b, following I have attached my .htaccess from that website.
Notice that the rewite base is uncommented at line 55, this website is hosted on a shared server with GoDaddy. The URL if you wish to check that things are working is www.gplforum.com
I can't think of anything that I have had a problem with due to it being installed in the root folder, however if anyone knows of any problems with later versions please let me know.
Never experienced any problem with RewriteBase to /, may it be with IcyPhoenix or my own websites.
Oh Dear,
The problem is that in the past some of those people who had/have installed IP to the root of the public folder.
Then used cPanel or the likes to add "hot-linking, re-directs" etc, and the whole script in the .htaccess file has collapsed into one continuous line.
Doesn't work all that well when it's just one BIG - - LONG string of commands. :P
And no-one said it CAN'T work in the root of the public folder - it just needs to be adjusted in the manner that you two have gone on and on about.
Ahh! Thanks for explaining.
Yeah I don't use Cpanel for any of my websites, I have access to a form of it with my Godaddy host but I only use the economy service with them anyway. (so there is no need for virtual-hosts and so on)
For my local server I am a die-hard unix guy, so everything is done manually. For example; to keep everything clean on my server, I install everything to it's own directory (/var/www/IcyPhoenix_1.3...) so I know what version I am running and everything like that. On top of that everything get it's own database accordingly.
I'm a bit lost in this topic... I still don't understand what the issue is. :sad:
If it is not solved yet, can you please try to explain again please?
Well this topic got split for some reason that I have yet to understand.
The original problem was here >> http://www.icyphoenix.com/viewtopic.php?f=2&t=8299
Not sure why it got split or what it has to do with the new title, but I have no problem.
If there are no issues and everything is working fine... I have no issues then! :mri:
Generation Time: 0.9398s (PHP: 2% SQL: 98%)
SQL queries: 16 - Debug Off - GZIP Enabled
