Turn Off Shoutbox And Seperate Chat Window
Subject: Turn Off Shoutbox And Seperate Chat Window
turn off the shout box and have a seperate chat window pls? i cant find the settings to do with chat. :(
Subject: Re: How Do I
would you please edit the post name. it´s somewhat confusing.
How do I , does´nt tell us anything
You can turn the shoutbox off in ACP
Thank you so much for your post.
To disable the forum index chat you will need to go where I have highlighted in the ACP.
screenshot_at_2012_01_22_02_57_50
To open the chat in a full page from the menu you will need to add a link to either "shoutbox_max.php" or "ajax_chat.php" in your dynamic menu via the CMS. This should look similar to the picture below.
screenshot_at_2012_01_22_03_03_24
You will need to switch to the "dynamic menu" for that link to work after adding it though.
Generation Time: 1.5931s (PHP: 14% SQL: 86%)
SQL queries: 17 - Debug Off - GZIP Enabled
