[SOLVED] AJAX Chat 0.8.3 - Possible? (Update: YES It Is ^_^)
Subject: [SOLVED] AJAX Chat 0.8.3 - Possible? (Update: YES It Is ^_^)
Hello!
I'm a big fan of the AJAX Chat 0.8.3 which is downloadable here.
I've already started the question in the german support forum of icy, but unfortunely no one could help me.
Well, now my question is comin' back again for me: How can i implement this chat into the Icy Phoenix 1.3.0.53b? (or git version)
Because i'm not really impressed of the main chat here in icy and, of course, i'm using AJAX Chat since years. (phpbb 3.x)
My Problem is, i can't get this chat works when i just download/install it for phpbb 2.
So how i can do this?
Any suggestions?
Thank you very much!
Greetings, Ghostsearcher
Subject: Re: AJAX Chat 0.8.3 - Possible?
that chat is very nice.
Can you try to contact the author and ask if he is willing to provide a fix for Icy Phoenix? He already ported the chat to other systems, maybe he will be happy to do that.
This may help. :mryellow:
http://sourceforge.net/apps/mediawi...tegration_howto
BTW MG the readme doc in the download also has the script for using it as a Shoutbox also. ;)
And the usual dribble of "How do I do this - Change that - Move something - Cross the "t's" and dot the "I's" :LOL:
http://sourceforge.net/projects/ajax-chat/forums/forum/774132
Hiho!
Yes, this chat is very nice, useful and got sounds, too. (thru flash-solution it's possible for everyone to hear it instead of wav)
In this case i have to tell ya, i knew the documentation site. (just forgot to tell you all -.- sorry!)
But there's a problem.
(i'm using obviously the right version: ajax_chat-0.8.3.zip)
In the documentation 4. lib/custom.php i can't figure it out what i have to do, because it's empty.
So i've also downloaded the phpbb2 version of the chat und copied following essentials into my custom.php, because the example of the phpbb3 implementation results to the common "Hacking attempt"-Site of icy:
define ('IN_PHPBB', true);
$phpbb_root_path = AJAX_CHAT_PATH.'../';
require($phpbb_root_path.'extension.inc');
require($phpbb_root_path.'common.'.$phpEx);
// phpBB session management:
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
But there's no extension.inc in icyphoenix, so it results to an error: :cry:
Warning: require(/xxx/xxx/xxx/board/chat/../extension.inc) [function.require]: failed to open stream: No such file or directory in /xxx/xxx/xxx/board/chat/lib/custom.php on line 12
Further problems could be exists under point 5. lib/class/CustomAJAXChat.php, but for now i have to run the chat.
Any suggestions?
Thank you!
P.s.: I've already contact the author before a few weeks w/o answer. -.-"
Hi.
I wanted to know what this chat looks like, so I've installed it ...
It's really easy !
Replace your chat/lib/custom.php with
  1. <?php
  2. /*
  3.  * @package AJAX_Chat
  4.  * @author Sebastian Tschan
  5.  * @copyright (c) Sebastian Tschan
  6.  * @license GNU Affero General Public License
  7.  * @link https://blueimp.net/ajax/
  8.  *
  9.  * IcyPhoenix integration :
  10.  * Informpro@http://icyphoenix.com
  11.  */
  12.
  13. // phpBB initialization:
  14. define('IN_ICYPHOENIX', true);
  15. if (!defined('IP_ROOT_PATH')) define('IP_ROOT_PATH', AJAX_CHAT_PATH.'../');
  16. if (!defined('PHP_EXT')) define('PHP_EXT', substr(strrchr(__FILE__, '.'), 1));
  17. include(IP_ROOT_PATH . 'common.' . PHP_EXT);
  18.
  19. // Start session management
  20. $user->session_begin();
  21. //$auth->acl($user->data);
  22. $user->setup();
Go to the page via your browser, and voilĂ  ! You're done.
Remove that file ... Now you can just go to chat/index.php (via your browser) and the chat works.
Don't forget, there's a configuration (chat/lib/config.php).
HF !
Huh that's GREAT! It works!
What did i wrong?
Well but i have just one question.
Because of my other phpbb 3 Forum, the login was automatically. The new chat works but im not automatically logged in if i visit my forum. I have to login manually.
Yes, sure i changed my config.php (force autologin:true). But i doesn't works.
Maybe something missing/wrong in a anywhere file?
Or is it normally in phpbb2?
Like i said in my phpbb3 i'm everytime auto loggedin so far i'm logged in my forum at the same time.
Hope ou can understand what i mean?
Thx!
Thank you and greetings, Ghostsearcher
ADDENDUM:
Sorry...just noticed: i can't get login. Only as guest but not as member of my forum.
Anything is wrong. -.-"
Yeah, I noticed the problem just after ...
Took quite time to understand ! But the problem is easy to see : sid is not re-sent each time.
It took quite time to understand HOW I can do that ... But after watching Matrix, everything is okay :D !
So, there's a lot of file to edit ...
Let's go !
OPEN
  1. login_ip.php
  1. $redirect_url = (!empty($redirect) ? urldecode(str_replace(array('&', ($redirect[0] == '?' ? '?' : ''), PHP_EXT . '&'), array('&', '&', PHP_EXT . '?'), $redirect)) : '');
BEFORE ADD
  1. if (substr($redirect, 0, 4) == 'chat')
  2. $redirect_url = $redirect;
  3. else
(this is because there's a problem with the ?redirect param when logging in)
Let's modify the shoutbox itself ...
OPEN
  1. chat/lib/template/loggedIn.html
  1. <script src="js/chat.js" type="text/javascript" charset="UTF-8"></script>
BEFORE ADD
  1. <script type="text/javascript">
  2. var _sid = "[SID/]";
  3. </script>
OPEN
  1. chat/lib/class/AJAXChat.php
FIND (line 61)
  1. $this->_requestVars = array();
AFTER ADD
  1. $this->_requestVars['sid'] = isset($_REQUEST['sid']) ? $_REQUEST['sid'] : null;
OPEN
  1. chat/lib/class/CustomAJAXChat.php
REPLACE THE WHOLE FILE WITH http://pastebin.com/iC4wjedV
OPEN
  1. chat/js/chat.js
FIND (ligne 119)
  1. this.ajaxURL = config['ajaxURL'];
  1. if (_sid)
  2. this.ajaxURL = config['ajaxURL'] + '&sid=' + _sid;
  3. else
  4. this.ajaxURL = config['ajaxURL'];
What have I done ?
Two things : first, I needed to replace login page with IP's login one (_ip).
Second : I needed to re-send SID each ajax call.
Everything should now work !
Hi Informpro!
First i have immediately to say: You are a GREAT man. ;)
Thank you very much for your support. Really great!!! :thanks: :banana_04:
BUT... :twisted: (always there's a "but" ^_~ )
...well, it's not very nice to say, but: It doesn't works - unfortunely. (i can't type anything, see no users and in the right upper corner you can see the "status bulp" - it should be normally green. Yellow and red "!" displays errors...hmmm, what's wrong here?)
I've copied all what you wrote here and i've re-checked it 3 times again... and it didn't worked.
And please note i'm using the GIT version of icy, if it's necessary to know. ;)
Well, i think there's probably a slightly tiny mistake anywhere in a string...maybe!? I don't know. I try to understand all the php strings, but i guess a monkey is smarter then me. WAHAHAHA :roll: :mricy:
What do you think about the mistake? There must be a little thing which is hook up the chat.
Please head on. You are very smart!!!
Much Greetings, Ghostsearcher
Addendum:
Maybe you should think about for a release of AJAX Chat for icy? Many people like this chat. ;)
Addendum #2: Ah i forgot to wrote: Yes, of course i've purged the forums cache. (because of login_ip.php)
Meh, gonna retry (I've installed it myself with that guide, for testing, but I maybe did something more), let me 10 minutes.
[20 later]Oke. Re-tryed ... Everything works here. Your config seems weird, I get the error "you have to allow cookies", but ... My cookies are allowed !
Did you do the install properly ?
And I can't create an account on your board. Could you provide me a test account via PM for testing ?
Hi there!
You got just a PM. (with slightly admin rights/ACP)
I also wonder about the cookie failure. Don't know why it is.
Yes i installed the chat properly because i could login.
All the things you said, i've copied them.
If you need another things, please let me know.
Thank you very much! ;)
Oke, so the bug is easy to spot.
It was juste a missing else statement - tried it with autologin, so I didn't noticed.
:thanks: :thanks: :thanks: :thanks: :thanks: :thanks:
It works!!!! ;)
Thank you sooo much!
Please notice my PM to you about a release for icy.
Thank you! ;)
Best greetings and wishes from me to you, Ghostsearcher
Addendum:
I forgot in that excitement :D to explain what informpro told me.
So here's the solution!
OPEN chat/js/chat.js
if (_sid) this.ajaxURL = config['ajaxURL'] + '&sid=' + _sid;
AFTER add
else this.ajaxURL = config['ajaxURL'];
Later at day i will add a complete package in the first post for the guys who want this chat using with icyphoenix. ;)
Please be patient...
Subject: Re: [SOLVED] AJAX Chat 0.8.3 - Possible? (Update: YES It Is ^_^)
I already edited my little guide ;).
Ghostsearcher wrote: [View Post]
While I share your enthusiasm,
I think it would be far better if InformPro wrote up the MOD instructions and packaged it as a complete MOD, as he is the one who actually wrote all the changes and will no doubt be the only one to support it in future.
Particularly when it will need to be converted to a "Plug-In" for the dev version.
Hi mort!
Well, it should be more like this packages. ;)
Support would be further given in they forum of ajax chat....hmm...so i thought about it. ^^
But i think you're right - i let it be. I'm not a pro coder.
Generation Time: 1.0327s (PHP: 2% SQL: 98%)
SQL queries: 18 - Debug Off - GZIP Enabled
