[bugs] Css -moz-opacity - - Album_allpics.php
Inactive User
Subject: [bugs] Css -moz-opacity - - Album_allpics.php
No longer used as you would no doubt be aware. :P
If you're not - - - - - - - - FF now only uses opacity. - - - - - - - - - - "BOOM!"
Warning: Unknown property '-moz-opacity'. Declaration dropped.
Source File: [h**p://***.icyphoenix.com/templates/default/common.css Line: 150]
PS: There are also some in the other .css in the /common folder.
Need a couple of &'s here ?
album_allpics.php
$album_view_mode_param = (!empty($album_view_mode)) ? '&mode=' . $album_view_mode : '';
$album_view_type_param = (!empty($album_view_type)) ? '&type=' . $album_view_type : '';
Subject: Re: [bugs] Css -moz-opacity - - Album_allpics.php
Are you sure that it is not working any more?
Do you have an official link to check the specifications?
Inactive User
Apparently it's only been an alias for opacity for quite some time :shock:
•History
Prior to Mozilla 1.7 (Firefox 0.9) the -moz-opacity property was implemented in a non-standard (inherited) way. With Firefox 0.9 the behavior changed and the property was renamed to opacity. Since then -moz-opacity was supported just as an alias for opacity.
•Gecko 1.9.1/ Firefox 3.5 and later do not support -moz-opacity. By now, you should be using simply opacity.
More: h**ps://developer.mozilla.org/en/CSS/opacity
Thanks, I will fix it.
Generation Time: 1.5171s (PHP: 2% SQL: 98%)
