SOLVED Link To Activity Mod
Subject: Link To Activity Mod
This could well be the most stupid thing I have asked, but I shall anyway.
I downloaded Activity Mod from here earlier today, & installed it on my latest version of Icy which I downloaded (from here) last week.
Installation went fine, all the edits worked, all the files copied into the correct directories etc etc.
Its all there in the ACP, the database is set up & working, games are installed & in categories, everything is peachy.
Apart from one small thing...
Where the hell is it? Outside of the ACP there is no trace of it anywhere. I've searched high, i've searched low, it is nowhere to be found.
Can anyone help?
Subject: Re: Stupid Question Alert
www.yoursite.com/activity.php
You have to create a link by yourself ;)
Vortex wrote: [View Post]
You are a genious sir! :)
:LOL:
Marking this topic as SOLVED and editing the topic title to be descriptive of the problem.
Subject: Re: Link To Activity Mod
Although my original problem has been solved, I have encountered another, so instead of clogging up the place with more of my nonsense ill stick it here & hope someone notices...
My problem/s this time are thus:
Game scoring: Why do nearly all my games score a big fat '1', no matter how I set things? The only ones that seem to score correctly are:
MaxiYatzy
tetris3
collapse
tetris2002
which came with the activity mod zip file.
billiards
billiards2
maxiyatzy
tetris2 also came with the zip file & do not score correctly, nor do any of my (400 odd) games I was using on my phpbb3 arcade.
When you submit a score (on a game where the scores register correctly) you get directed to http://www.blahblahblah.net/newscore.php.
When you submit on a game where it doesn't work you get directed to http://www.blahblahblah.net//index.php?act=Arcade&do=newscore. Sounds good, but its actually just the site index page (i.e http://www.blahblahblah.net//index.php).
Now i'm guessing the scores not registering & the page redirects are related issues, anyone ever seen this before & know a fix?
While i'm on, where can I find games that do register scores with activity mod? I've tried all the links i've seen & googled it but seem to keep hitting dead ends.
Subject: Re: Activity Mod Block
Unfortunately not all games have been designed for Activity MOD.
I have plenty of them... all downloaded from the activity site http://phpbb-amod.com/ but I don't know if it is active anymore.
Thanks for that, but it appears they don't like me LOL
phpBB Security© Thinks You Should Go Away.
You have been blocked because you have permission to be staff, but the admins did not grant you permission in the security panel.
If you feel you have reached this message in an error due to the site, please contact the admin at .
Subject: Re: Activity And Global_blocks???
Same for me... :sad:
If you don't find any game using Google I can create a pack for you with all the ones downloaded from AMod site... :wink:
That would be fantastic! :D
Generation Time: 1.2925s (PHP: 1% SQL: 99%)
SQL queries: 32 - Debug Off - GZIP Enabled
