hello,my home page isn't centered,because at 1024x768 there is the bar for go at left and right,what i can do for centered my homepage?
there is a way for change the blocks size?
thanks
p.s.
the link of my site is in the profile
How To Centered My Home Page
Subject: Re: How To Centered My Home Page
The problem is that FF doesn't know how to wrap the content. It's not too bad with IE7 :P
at me explorer do the same thing at 1024x768 :cry:
what i can do for change the blocks size and centered the home?
thanks
thanks
In CMS Management > CMS Configuration > Default Site Page, you could try adjusting the left and right columns there.
But I don't think it's going to work because of what you have in the home page. Maybe it would be better if you went to 2 (two) columns. ;)
Ok Aleeee,
I've had a look at the html and the problem appears to be the banner block at the bottom, that FF wont wrap the url. As in the pic.
So you would need to address that first. ;)
ok,what i can do for fix it?
p.s.
i have try to set the large of colums,if you view my site now it centered with explorer with the banner block but it isn't centered with firefox and opera
thanks
p.s.
thanks
With FF take a html dump with view source and save to disk. Open it with FF and you will see that the it's far too wide. :(
Open the dump with an editor and Find the script below and remove it >
You get the idea of what you have to address to fix the problem - Even if you edit the HTM file to first get some idea of what is causing, and how to fix the problem. ;)
PS: There is also no need to quote the post immediately above the next post. ;)
No, You need to take a html dump of index.php using FF and "view source" - and edit that to find out what is pushing the Index too wide. ;)
Generation Time: 0.9077s (PHP: 2% SQL: 98%)
SQL queries: 32 - Debug Off - GZIP Enabled
