I can't seem to figure out how to set up the news block to show the recent news on the site.
I have gone into ACP to News configuration but am not getting anywhere. Can someone post a link or give me simple step by step instructions on how to get the news to show up in the block on the index page?
SOLVED - News Block And Configuring News?
Subject: SOLVED - News Block And Configuring News?
Subject: Re: News Block And Configuring News?
You have to go to CMS Panel >> add News block on portal>>> then try New Post >>select category right under subject line.
http://www.icyphoenix.com/viewtopic...ghlight=#p22916
hope this helps :)
hope this helps :)
Thank you xmenfile that helped very much. Not sure why I complicate things LOL but I do .. Thanks it is working now with no issues.
no worries. I did the same way and that's how i learn about IP. :mricy: :mricy:
Generation Time: 0.9672s (PHP: 2% SQL: 98%)
SQL queries: 16 - Debug Off - GZIP Enabled
