Upgrade From IP 1.0.10.10
Subject: Upgrade From IP 1.0.10.10
Hello, I've read the post for upgrade from IP 1.0.9.9 Beta to IP 1.0.11.11, but I patch the IP 1.0.9.9 from 1.0.10.10 as Zuker said me...
It's same to upgrade from 1.0.9.9 that from 1.0.10.10?
Thanks for your replies!!
PD: Sorry for my bad english... :(
Greetings!!
Subject: Re: Upgrade From IP 1.0.10.10
Choose Upgrade From 1.0.5.5.
Thanks MG for your reply.
Greetings!!
Sorry for continue this thread, but I have more problems...
You said that I have to use the process as if I have upgrade from IP 1.0.5.5, but, do you refer to the data base upgrade, no?
I upgrade the data base from IP 1.0.5.5, but I have to use the process of upgrade from IP 1.0.9.9, no?
Greetings!!
Choose Upgrade From 1.0.5.5... don't worry, it will work fine.
Thanks MG!! You are the best!!
Greetings!!
Generation Time: 1.4785s (PHP: 10% SQL: 90%)
SQL queries: 31 - Debug Off - GZIP Enabled
