Tags And Keywordsbbcode, customization, flv player
Post BBCODE - CUSTOMIZATION - FLV Player Allow Fullscreen
On FLV Player you can insert width and height of the Video
[flv width=386 height=240]http://content.bitsontherun.com/videos/bkaovAYt-364766.mp4[/flv]
Can someone tell me how I can insert allow fullscreen?  "allowfullscreen","true"
Post Re: FLV Player Allow Fullscreen
I started playing with this but you know how good a coder I am
however I did manage to get it working with a fullscreen button by replacing the player file and modding includes >> bbcode.php
player downloaded and simply renamed to overwrite the original player:
http://www.longtailvideo.com/players/jw-flv-player/
Code I modified for the test in bbcode.php:
                elseif ($tag === 'flv')
                    $html = '<object type="application/x-shockwave-flash" width="' . $width . '" height="' . $height . '" wmode="transparent" data="flv_player.swf?file=' . $content . '&amp;autoStart=false"><param name="movie" value="flv_player.swf?file=' . $content . '&amp;autoStart=false"/><param name="wmode" value="transparent"/></object>';
Promise not to laugh if this is a silly replacement but this worked for me for this fast try:
                    $html = '<object type="application/x-shockwave-flash" width="' . $width . '" height="' . $height . '" wmode="transparent" allowfullscreen="true" data="flv_player.swf?file=' . $content . '&amp;autoStart=false"><param name="wmode" value="transparent"/><param name="allowfullscreen" value="true"/><param name="movie" value="flv_player.swf?file=' . $content . '&amp;autoStart=false"/><param name="wmode" value="transparent"/></object>';
Keep in mind ..I'm not saying this is how it should be done   I even expect this to be incorrect somewhere
Thanks Joshua203, for your work...
I can now see the fullscreen button under the video... but it didn´t work if you click on it.
Maybe I should do anything with the new JS files
Thanks for any help.
That's funny because these messy edit above did make it work fully for me, only thing did n't like was the screen at the end of the movie but as I'm sure you noticed ..there is a lot more possible with this player
so in short ..the button was functioning when I tested
Try removing this from the above string because they do have a default value that is possibly holding the size down.
My first test was working fine... but I had to clean the cache
Anyway... I used a older version of swf file
http://developer.longtailvideo.com/...3.14?order=name
Because it looks similar to the old one and there should not be any license problems.
Thanks for your help.
Thanks TheSteffen, I prefer that version as well.
I did the following to enable fullscreen and to have a standard placeholder for all videos:
  • Download the Zip-archive at the bottom of the page linked to in TheSteffen's last post above.
  • Open the archive and extract the file mediaplayer.swf.
  • Rename to flv_player.swf and upload to the root of your Icy Phoenix installation.
  • Create a file called clicktostart.gif for a placeholder and upload it to the root as well. I made it 320x180, which is small and 16:9.
  • OPEN includes/bbcode.php
  • FIND
                        $html = '<object type="application/x-shockwave-flash" width="' . $width . '" height="' . $height . '" wmode="transparent" data="flv_player.swf?file=' . $content . '&autoStart=false"><param name="movie" value="flv_player.swf?file=' . $content . '&autoStart=false"/><param name="wmode" value="transparent"/></object>';
  • REPLACE WITH
                        $html = '<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="' . $width . '" height="' . $height . '" id="single1" name="single1"><param name="movie" value="flv_player.swf"><param name="allowfullscreen" value="true"><param name="allowscriptaccess" value="always"><param name="wmode" value="transparent"><param name="flashvars" value="file=' . $content . '"><embed type="application/x-shockwave-flash" id="single2" name="single2" src="flv_player.swf" width="' . $width . '" height="' . $height . '" bgcolor="undefined" allowscriptaccess="always" allowfullscreen="true" wmode="transparent" flashvars="file=' . $content . '&image=clicktostart.gif" /></object>';
If you don't care for the placeholder, just remove this bit:
Note: If you already posted some videos on your website using the bbcode [flv] before making the above changes, you may have to go to each of those posts, click 'Edit' and then click 'Submit' to parse the altered html code. purge your cache in ACP.
scorpsportalSend private messageVisit poster's website
Awesome info here!! I will try this out on my board.
I am wondering though, is it possible to tweak the YouTube BBcode in the same manner?
HansSend private messageVisit poster's website
Thanks scorpsportal for your instruction.
Hans: yes, it is similar... you have to insert allowfullscreen="true"
TheSteffen wrote: [View Post]
Awesome! I will try that out! Thank you both very much!
Post Re: BBCODE - CUSTOMIZATION - FLV Player Allow Fullscreen
Thanks to everyone who contributed, topic moved to Docs section.
