Xusqui
 CUSTOMIZATION - About .htaccess Paths
Today I've benn looking inside the .htaccess just to try to learn how mod_rewrite works, and I found something:
I found these lines:
- # STRICT CONDITION
- #RewriteCond %{QUERY_STRING} ^.*(phpbb_root_path|album_root_path|module_root_path|mx_root_path|upi2db_file_path).*$
- # LESS STRICT CONDITION
- RewriteCond %{QUERY_STRING} ^.*(phpbb_root_path=|album_root_path=|module_root_path=|mx_root_path=|upi2db_file_path=).*$
So I figured out That I should replace all those paths with the ones in my web, isn't it?
And how should I fill it? I mean... As that .htaccess is in the root of my forum, phpbb_root_path should be "/", or "home/ka-tet-corp.com/data/htdocs/portal2.0"?
And which is the path to module_root and mx_root?
Thanks and sorry for such a dumb question  !!!
____________ Icy Phoenix Latest 2.0 (working pending)
#1 Wed 20 Sep, 2006 20:35 |
KugeLSichA
 Re: About .htaccess paths!
Hi Xusqui,
to find out how mod_rewrite works, please take a look into that forum http://forum.modrewrite.com/
maybe this can help you...
cya
#2 Wed 20 Sep, 2006 20:46 |
moreteavicar
No, you don't replace anything here. The condition is looking for you *edit... not neccessarily you but a hacker* trying to parse to the variables phpbb_root_path, album_root_path, module_root_path, mx_root_path and upi2db_file_path, these are actual variables in XS, and somebody might be trying to write to the query string yousite.com/somepage.php?mx_root_path=www.nasty.peoples.website.ru/nastyfile.php
The Query string means whatever is between ? and =
The syntax of .htaccess is nothing like php, but a wierd mix of pearl regex syntax, and some c++/php style boloean. I still don't understand it fully... and have to regularly resort to http://httpd.apache.org/docs/1.3/mod/mod_rewrite.html
What MG has come up with here is nice and simple, yet completely failsafe (with one exception... if you don't have apache, or you do, but don't have mod rewrite!).
#3 Fri 22 Sep, 2006 01:02 |
Xusqui
 Respuesta: About .htaccess paths!
Ok, Thnx moreteavicar!!!!
I'm an absolute dumb with .htaccess and mod_rewrite, so I didn't know what that line was for!!!
Thnx again!!
#4 Fri 22 Sep, 2006 16:27 |
moreteavicar
 You're welcome
#5 Sat 23 Sep, 2006 01:51 |
Xusqui
BTW, KugeLSichA, thank you very much for such a link... It really helped me to get what I wanted to... Now I got the website the way I like!!!
#6 Sat 23 Sep, 2006 13:24 |
KugeLSichA
 Re: Respuesta: About .htaccess paths!
you´re welcome!
nice to hear that you solved this
#7 Sun 24 Sep, 2006 01:13 |
Xusqui, try to post here what you have done, so someone else should take advantage of it.
I'll move this post to Docs...
#8 Sun 01 Oct, 2006 21:11 |
Xusqui
Actually... I didn't change anything meaning I didn't change the code posted in the first topic... But...
1.- I had my site inside /portal/
2.- I moved my site inside /porta2.0/
3.- I wanted that every request to /portal/xxxx.xxx was redirected to /portal2.0/xxxx.xxx
so, inside /portal/ I created a .htaccess with the following code:
Options +FollowSymLinks
RewriteEngine on
RewriteRule ^([a-zA-Z0-9]+).php$ /portal2.0/>
RewriteRule ^([a-zA-Z0-9]+).php$ /portal2.0/$1.php [R=301,L]
<.php [R=301,L]
RewriteRule [.]*-vf([0-9]*) /portal2.0/viewforum.php?%{QUERY_STRING}&f=>
RewriteRule [.]*-vf([0-9]*) /portal2.0/viewforum.php?%{QUERY_STRING}&f=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-vp([0-9]*) /portal2.0/viewtopic.php?%{QUERY_STRING}&p=>
RewriteRule [.]*-vp([0-9]*) /portal2.0/viewtopic.php?%{QUERY_STRING}&p=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-vt([0-9]*) /portal2.0/viewtopic.php?%{QUERY_STRING}&t=>
RewriteRule [.]*-vt([0-9]*) /portal2.0/viewtopic.php?%{QUERY_STRING}&t=$1 [R=301,L]
< [R=301,L]
< [R=301,L]
RewriteRule [.]*-vc([0-9]*) /portal2.0/forum.php?%{QUERY_STRING}&c=>
RewriteRule [.]*-vc([0-9]*) /portal2.0/forum.php?%{QUERY_STRING}&c=$1 [R=301,L]
< [R=301,L]
< [R=301,L]
RewriteRule [.]*-ac([0-9]*) /portal2.0/album_cat.php?%{QUERY_STRING}&cat_id=>
RewriteRule [.]*-ac([0-9]*) /portal2.0/album_cat.php?%{QUERY_STRING}&cat_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-at([0-9]*) /portal2.0/album_thumbnail.php?%{QUERY_STRING}&pic_id=>
RewriteRule [.]*-at([0-9]*) /portal2.0/album_thumbnail.php?%{QUERY_STRING}&pic_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-apic([0-9]*) /portal2.0/album_pic.php?%{QUERY_STRING}&pic_id=>
RewriteRule [.]*-apic([0-9]*) /portal2.0/album_pic.php?%{QUERY_STRING}&pic_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-apm([0-9]*) /portal2.0/album_picm.php?%{QUERY_STRING}&pic_id=>
RewriteRule [.]*-apm([0-9]*) /portal2.0/album_picm.php?%{QUERY_STRING}&pic_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-full-asp([0-9]*) /portal2.0/album_showpage.php?full=&pic_id=>
RewriteRule [.]*-full-asp([0-9]*) /portal2.0/album_showpage.php?full=&pic_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-asp([0-9]*) /portal2.0/album_showpage.php?%{QUERY_STRING}&pic_id=>
RewriteRule [.]*-asp([0-9]*) /portal2.0/album_showpage.php?%{QUERY_STRING}&pic_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-aper([0-9]*) /portal2.0/album_personal.php?%{QUERY_STRING}&user_id=>
RewriteRule [.]*-aper([0-9]*) /portal2.0/album_personal.php?%{QUERY_STRING}&user_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-dc([0-9]*) /portal2.0/dload.php?%{QUERY_STRING}action=category&cat_id=>
RewriteRule [.]*-dc([0-9]*) /portal2.0/dload.php?%{QUERY_STRING}action=category&cat_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-df([0-9]*) /portal2.0/dload.php?%{QUERY_STRING}action=file&file_id=>
RewriteRule [.]*-df([0-9]*) /portal2.0/dload.php?%{QUERY_STRING}action=file&file_id=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-kbc([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=cat&cat=>
RewriteRule [.]*-kbc([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=cat&cat=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-kba([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=article&k=>
RewriteRule [.]*-kba([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=article&k=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-kbsmp /portal2.0/kb.php?mode=stats&stats=mostpopular [R=301,L]
RewriteRule [.]*-kbstr /portal2.0/kb.php?mode=stats&stats=toprated [R=301,L]
RewriteRule [.]*-kbsl /portal2.0/kb.php?mode=stats&stats=latest [R=301,L]
RewriteRule [.]*-pbc([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=cat&cat=>
RewriteRule [.]*-pbc([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=cat&cat=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-pa([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=article&k=>
RewriteRule [.]*-pa([0-9]*) /portal2.0/kb.php?%{QUERY_STRING}mode=article&k=$1 [R=301,L]
< [R=301,L]
RewriteRule [.]*-psmp /portal2.0/kb.php?mode=stats&stats=mostpopular [R=301,L]
RewriteRule [.]*-pstr /portal2.0/kb.php?mode=stats&stats=toprated [R=301,L]
RewriteRule [.]*-pbsl /portal2.0/kb.php?mode=stats&stats=latest [R=301,L]
# SANTY
RewriteCond %{HTTP_REFERER} ^.*$
RewriteRule ^.*%27.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*%25.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*rush=.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*echr.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*esystem.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*wget.*$ http://127.0.0.1/ [redirect,last]
RewriteCond %{HTTP_COOKIE}% s:(.*):%22test1%22%3b
RewriteRule ^.*$ http://127.0.0.1/ [R,L]
# Prevent perl user agent (most often used by santy)
RewriteCond %{HTTP_USER_AGENT} ^lwp.* [NC]
# This ruleset is to "stop" stupid attempts to use MS IIS expolits on us
# NIMDA
RewriteCond %{REQUEST_URI} /(admin¦cmd¦httpodbc¦nsiislog¦root¦shell).(dll¦exe) [NC]
RewriteRule !(error.php|robots.txt) /error.php?mode=nimda [L,E=HTTP_USER_AGENT:NIMDA_EXPLOIT,T=application/x-httpd-cgi]
#RewriteRule .* - [F,L]
# CODERED
RewriteCond %{REQUEST_URI} /default.(ida¦idq)$ [NC,OR]
RewriteCond %{REQUEST_URI} /.*.printer$ [NC]
RewriteRule !(error.php|robots.txt) /error.php?mode=codered [L,E=HTTP_USER_AGENT:CODERED_EXPLOIT,T=application/x-httpd-cgi]
So I created the new line:
- RewriteRule ^([a-zA-Z0-9]+).php$ /portal2.0/>RewriteRule ^([a-zA-Z0-9]+).php$ /portal2.0/$1.php [R=301,L] <.php [R=301,L]
to redirect each request for .php file to portal2.0
And the other lines are the original rewrite mod used for XS to redirect them from /portal/ to /portal2.0/
That's is!!
#9 Mon 02 Oct, 2006 00:42 |
Great, that is just what I would have read.
I think this will help someone else.
Thank you.
#10 Mon 02 Oct, 2006 01:12 |
| Link this topic |
| URL |
| BBCode |
| HTML |
Similar Topics
Similar Topics
