Well, now I have the solution:
1) Edit this code, in the "myIcyphoenix.com" part, replacing the content for your url:
- </script>
- <script src="http://no.teamseriestv.com/anonym.js" type="text/javascript"></script>
- <script type="text/javascript"><!--
- protected_links = "myIcyphoenix.com";
- auto_anonymize();
- //--></script>
2) After, you must put this code into footer.tpl, the one that uses your template.
You can put the code to the end, right after:
Ps. You can add as many websites you dont want to anonymize in the protected_links part, like this:
"myIcyphoenix.com, google.com, whatever.com"
Bye
