Hi all!
As I have been speaking about it here, I have upgraded my site from 1.2.0.27c to 2.0.
The problem i am having is something like this:
When I go to an specific page of a topic, the destiny is the Forum of the topic, not the page selected.
I have an user which you can test if you want.
username: jefecillo
password: icyphoenix
www.club-205.com/ip/
Just browse to a topic with more than one page. Try to use the shortcuts (going to the last topic, or the first unread, or a page concretely), and you will find the wrong behavior.
SOLVED Wrong Links After Update
Subject: Re: Wrong Links After Update
Hi, You are right Joshua, I closed it to retry, and I forgot to reopen it.
I've founded the origin of the problem. I am not user_id = 2, i am Administrator but second one. Because of this, during the update, the last part, while running install, told me I had no permissions in that area. I re-did it with the admin user_id = 2 and now I am in install page fixing this problem
I will report the final conclusion.
Thank you again.
Editing: I have found this problem fixed doing the install/install.php with first User. I mark it as solved and begin a new topic.
Thankyou!
Thank you again.
Thankyou!
Congratulations for solving it your self, and thanks for marking this SOLVED Jefazo :wink:
jefazo666 wrote: [View Post]
I know it is solved...
But you can make other users to founder or main admin if you wish.
Take a look at this code \includes\constants.php
Only to let you know
// FOUNDER ID, this is the ID of the main admin of the site, only this user canc access special features of the site and this ID is also used to send Welcome and Birthday PM
define('FOUNDER_ID', '2');
// ALLOW ONLY FOUNDER ACP, by setting this to true only the FOUNDER will be able to access ACP
define('ONLY_FOUNDER_ACP', false);
// Insert here the IDs of the main admins separated by commas, they will be able to access special features in ACP
// Allowed features: Action Logs, Private Messages, DB Tools, Templates Edit (XS Style)
// If the constant is deleted then every admin is able to access the Full ACP
define('MAIN_ADMINS_ID', '2');
I have full access to ACP, I think I changed the group of my user, or the type, I don't remember How I did it.
Maybe for running install.php I need your hint. Thank you!
TheSteffen wrote: [View Post]
Subject: Re: [SOLVED] Wrong Links After Update
You can see if you have full access or not in ACP
On left site you get "DB And Security"... below "Styles & Templates"
If you have this "DB And Security", you have full access ;-)
Generation Time: 0.9576s (PHP: 3% SQL: 97%)
