Post How To Add New Pages To phpBB XS
Hello,
I need to convert some modules previously made by me for MkPortal. Our old portal before XS.
I studied some php pages in root like forum.php, kb.php, etc. but I didn't undersand very well the procedure to use on XS.
I've seen that the db connections is stored in the variable and class $db, so I need to write
  1. global $db;
  2.
In this modules I need to look into user tables if user filled some field, so, if filled the user will be able to see and ordering form.
Some fields are pre-filled reading the content of user table, and some field are left to be filled by the user.
After some JS field validation the user will be able to send the form to another page that adds a record with some fields (the post data previously filled by the user) in a custom table.
It's very simple but I don't know what I have to implement to have my script to work into XS framework sharing its informations and how to draw the final output, to show the MAIN LINK column.
To send queries to the db I found this methods of class $db:
  1. $query = $db->sql_query("SELECT * FROM table;");
  2. while ($row = $db->sql_fetchrow($query)) {
  3.        //my script
  4. }
  5.
It will be very useful a small guide to make our own modules.
Thanks!
EradicatorSend private messageVisit poster's website
Post Re: How Make Our Own Modules/pages
here a sample php page using the phpbb functions:
  1. <?php
  2. define('IN_PHPBB', true);
  3. $phpbb_root_path = './';
  4. include($phpbb_root_path . 'extension.inc');
  5. include($phpbb_root_path . 'common.'.$phpEx);
  6.
  7. //
  8. // Start session management
  9. //
  10. $userdata = session_pagestart($user_ip, PAGE_VIEWMEMBERS);
  11. init_userprefs($userdata);
  12. //
  13. // End session management
  14. //
  15.
  16. $sql = "SELECT column_name FROM " . CONSTANT_WITH_THE_NAME_OF_THE_TABLE . " WHERE column_operator_value";
  17.
  18. //the constants with table names are stored in includes/constants.php
  19. //i.e.: " . POSTS_TABLE . "
  20.
  21. if( !($result = $db->sql_query($sql)) )
  22.
  23. //if the query fails it shows the error
  24.
  25. {
  26.    message_die(GENERAL_ERROR, 'Could not query posts table', '', __LINE__, __FILE__, $sql);
  27. }
  28.
  29. //otherwise
  30.
  31. $result = $db->sql_query($sql);
  32.
  33. //YOUR SCRPT ($var = ... $var1 = ...)
  34.
  35. //this frees the used and useless resources
  36.
  37. $db->sql_freeresult($result);
  38.
  39. //
  40. // Generate page
  41. //
  42. $page_title = "Page Title";
  43. include($phpbb_root_path . 'includes/page_header.'.$phpEx);
  44.
  45. //here we set the tpl file name where parsing the page
  46.
  47. $template->set_filenames(array(
  48.     'body' => 'new_page.tpl')
  49. );
  50.
  51. $template->assign_vars(array(
  52.     'VAR' => $var,
  53.         'VAR1' => $var1
  54.     ));
  55.
  56. $template->pparse('body');
  57.
  58. include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
  59. ?>
then we must create the tpl file (new_page.tpl in this case)
  1. <table width="100%" border="0" class="forumline">
  2. <tr>
  3. <td><b>{VAR}</b></td>
  4. </tr>
  5. </table>
z3d0Send private messageVisit poster's website
Thanks!
And how can I show the XS Main Links menĂ¹?
Modify the file templates/ca_aphrodite/nav_quick_links.tpl
I have another question about the page, how I can do this page rewriteable ? I mean url friendly ? Like the other pages ... I have rewrite ON.
LuckySend private message
Lucky wrote: [View Post]
I don't mean how to edit quick_links, but how to SHOW the quicklinks on the left of my module.
Thanks!
Post Re: How Make Our Own Modules/Pages
If you had looked into contrib folder... you should have found this: contrib/empty_page/!
This is just a "ready to use" empty page for phpBB XS...
Eradicator wrote: [View Post]
Using this in your template:
  1. <!-- INCLUDE nav_box.tpl -->
What do you mean by this?
You can just assign to the page the name you wish... no need to use a function to rename it!
P.S.: topic moved to Docs.
i think he means, how he can use rewrite engie (mod rewrite) but im not sure
Play Games at GamesCampus!
Post Re: How To Add New Pages To phpBB XS
I think he want the new page with the url rewritten... but is completely useless... since you can name the page as you wish, and there is no need to dynamically rename that page.
Post Re: How To Add New Pages To PhpBB XS
Yes ! what I mean was to have a new page with the url friendly, for example not www . mywebsite . com/newpage.php but www . mywebsite . com/newpage.html ... but thinking I have understood that it's completely useless !!! as MG typed.
I have understood about the urls friendly (rewritten) that are important for search engine bots only if I have a "complex" address like www. ... .com/newpage.php?mode=23&.....
It's right ?
If the content for empty page must be edited inside the tpl file using html codes ... how can I have the content inside a block like every thing in XS portal ?
I mean something like wellcome block, in fact, the html code appeas inside a block with a bar etc. etc.
Use standard HTML... or if you want to use blocks... then create new pages using IM Portal.
How can I make this page visible only to registered users?
do you want to hide link or to redirect to login ?
*VOLVO CLUB*
This was for ipb1.3:
  1. $email=$userdata->member['email'];
  2. $nick=$userdata->member['name'];
  3. $id_utente=$userdata->member['id'];
  4.
How can I make the same with XS?
difus wrote: [View Post]
I think that the XS' unauthorized access will be good!
I want to allow only usergroup "utenti". The related group_id can be found in phpbb_groups table?
