Icy Phoenix 1.2.0.27c Patch
Hi all,
here is a patch for Icy Phoenix 1.2.0.27 which fixes all known bugs (until today 2008/08/22) of the latest stable release.
All you have to do, in order to apply this patch, is to replace all files in your Icy Phoenix 1.2.0.27.
And apply a small DB change to upgrade the version.
You are invited to update your sites ASAP.
Icy Phoenix 1.2.0.27c Patch Package Name: Icy Phoenix Patch
Package Version: 1.2.0.27c (it is a cumulative patch since 1.2.0.27)
Release Spot: Five Rings Patch
DOWNLOAD: Icy Phoenix 1.2.0.27c Patch
Only changed files since Patch B: http://www.icyphoenix.com/_release/ip_20080821_12027_patch.zip
Changelog: http://test.lineameteo.it/diff_tools/install.xml
P.S.: if you downloaded full package after 2008/08/22 you don't need to apply this patch.
P.P.S.: special thanks to Andrea75 for the help in creating this patch.
Edited by andrea75, Sat 23 Aug, 2008 10:40: Added changelog |
#1 Fri 22 Aug, 2008 19:53 |
New Player
Re: Icy Phoenix 1.2.0.27c Patch
thanks MG
can you show a completely changelog?
#2 Fri 22 Aug, 2008 20:05 |
ALTUN
Muhammet Altun
Thank you worthy Mighty Gorgon
#3 Fri 22 Aug, 2008 23:01 |
novice programmer
New Player, Come on, making a change log from the first XS version is almost imposible...
#4 Sat 23 Aug, 2008 00:32 |
Limun
thank you
question...
so if i alredy have Patch B (whic i dont know) and if i update with Icy Phoenix 1.2.0.27c Patch its gona be ok ?
#5 Sat 23 Aug, 2008 01:29 |
New Player
i mine from the b to the c patch....
#6 Sat 23 Aug, 2008 09:44 |
andrea75
thank you
question...
Sure, you have to donwload only the changed files from second link.
I have added the changelog. You can find it on the first post.
____________ My Icy forum: www.lineameteo.it
#7 Sat 23 Aug, 2008 09:52 |
Limun
thank you
question...
noo, you didnt understand maybe..i dont remeber if i alredy patched with "b" so if i have patched before and if i update with Icy Phoenix 1.2.0.27c ( not changed files from second link) what gona happend ?
#8 Sat 23 Aug, 2008 11:45 |
New Player
thank you!
#9 Sat 23 Aug, 2008 11:58 |
novice programmer
All patchs are cumulatives, twich means it is a sum of "a" bugs fixes, "b" bug fixies, and "c" bug fixies.
#10 Sat 23 Aug, 2008 15:25 |
xmenfile
thank you
question...
Correct me if i misunderstand. I have patch B before and I just applied patch C from 2nd link to my site. So far so good, no error yet knock on wood
#11 Sat 23 Aug, 2008 18:47 |
novice programmer
I meant the link in the box, the cumulative patch.
#12 Sat 23 Aug, 2008 19:48 |
Chaotic
thank you
question...
That changelog just saved me a lot of cursing... LOL.
Thanks Andrea!
#13 Sun 24 Aug, 2008 18:35 |
ThE KuKa
Nice work with the changelog Andrea !!!
#14 Mon 25 Aug, 2008 02:20 |
