Page 1 of 4
DWho
 My Profile Space Mod
Hi
What does this Mod do
- profiles can be designed by your members.. using the custom tool
- or you can make your own designs and allow you members to choose
- members can place information on their profile in the order of what they like
- post a bulletin on your profile
- make friends with other members and display their photos on your profile
- top friends list
- send comments to your friend the comments appear on their profile and vice versa
- members can add information to their profiles using Icy bbcode (display you tube videos flash items etc
- block members from seeing your profile or making comments to you
- adding friends through this mod is not the same as the friends built into Icy
- members can report profiles that may be not in line with the rules of your site
- admins can view profiles and review if they are ok send a message to the member asking them to remove anything if necessary
- set up search features so members can find other members with the same interests or details
- full admin side configuration
- works with FAP and Icy bday system
- many more features.. and add ons that can be made available
1.3 Version
After a week of updating a million or so files (well it felt like that) here is the first version of mps mod for Icy Phoenix 1.3
Version 1.3
This can be used live for ICY 1.3... this is a large mod I have tested for bugs and have had so far no reports back on errors.. if you do have a problem please post here
Anyway....
you need to run the install file before making any changes to your site or you will not be able to get on your site..
I would appreciate if anyone could translate the lang files for other members on the site... and to test for any errors anywhere within the mod...
If anything needs changing please post about it so we can make this a great add on...
All html has been removed from posting in text boxes from this mod for obvious reasons but Icy bbcode will work in any text boxes though you will have to type the code instead of using the standard buttons in some fields...
This is built for frozen icy as it is the default theme on a fresh install... If you need it for another theme please post here with the name of your theme (click on the link)
Always a work in progress but this is full working on live sites
After you have made all the changes and uploaded your files you must go to ACP find MPS on the left hand side.. find config check the settings and hit submit... you must hit submit even if you do not change anything
this makes the mps active...
There are pre modded files included in the package but you still have to run the database update file and add all the extra files that are included in the package..
two small errors in admin file found if you have already installed please upload these 2 files and copy over to your site..
http://www.icyphoenix.com/viewtopic.php?p=41786#p41786
http://www.icyphoenix.com/viewtopic.php?p=41795#p41795
if it is a fresh install please just use the download as it has been updated
Download Here
Demo Here
UPDATE
Complete Spanish version of the MPS Mod now available..
Please download from here
That is all for now..
Enjoy
#1 Tue 21 Jul, 2009 17:06 |
spydie
 Re: My Space Profile Mod
nice job
BIG Thank´s, DWho
____________ Out of Order
#2 Tue 21 Jul, 2009 17:11 |
DWho
nice job
BIG Thank´s, DWho
#3 Tue 21 Jul, 2009 17:22 |
xmenfile
oh wow, this is a great gift
Thank you DWho
#4 Tue 21 Jul, 2009 18:31 |
Chaotic
This looks very promising, DWho. I know tons of IP users will be downloading and giving this a try on their website.
Great job!
#5 Tue 21 Jul, 2009 23:31 |
KugeLSichA
Really great work DWho... thanks for sharing
#6 Wed 22 Jul, 2009 08:29 |
xmenfile
I have finished installed with pre-moded files. But got this errow message when i tried to submit the config per your instruction.
Failed to update general configuration for header_table_text
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's FREE.
' WHERE config' at line 2
UPDATE phpbb_config SET config_value = '
Welcome to community
edited: did you name "icy_pheonix" in purposed?
We share and discuss current discount, coupon, onsale, promotion, hot deals on internet or local stores; try to help everyone to save a buck or 2. Join now, it\''s FREE.
' WHERE config_name = 'header_table_text'
Line : 84
File : admin_mps_config.php
I am not sure this MPS or IP error, because I changed Site Description in ACP>Configuration>Server to "Community" ONLY and submit it fine. Somehow DB did not change, so i managed to change it manually.
Also, i found 2 errors on MPS
1. icy_ph eonix folder mispelled
2. missing "Visit users myspace page" image
#7 Thu 23 Jul, 2009 04:11 |
DWho
1. icy_pheonix folder mispelled
hi
I cannot see the folder anywhere in the download named icy_ph eonix can you please poing in the right direction..
what template are you using as the images have only been made for frozen phoenix as that is the standard install template...
DEBUG MODE
We share and discuss current discount, coupon, onsale, promotion, hot deals on internet or local stores; try to help everyone to save a buck or 2. Join now, it''s FREE.
Line : 84
I am not sure this MPS or IP error, because I changed Site Description in ACP>_mg;Configuration>_mg;Server to "Community" ONLY and submit it fine. Somehow DB did not change, so i managed to change it manually.
did you run the dabase_update.php file first before adding the premodded files... ?
this is not part of the mps mod so I do not know why you have this error ... the test site I made is using the premodded files... and I have not errors ..
can you tell me exactly what you did...
#8 Thu 23 Jul, 2009 10:39 |
OwnageWorld
Thanks for all the hard work Dwho!
This is an excellent mod in addition to IcyPhoenix!
You make IP profiles more interactive & personal!
Im downloading ATM and I will post any discrepancies/ errors.
#9 Thu 23 Jul, 2009 17:36 |
xmenfile
sub folder under template folder is mispelled. If you upload them, you'll have icy_phoenix and icy_pheonix folders under templates. minor error, but just want to point it out to everyone else
In regard to my Site Description error, i updated my site to the latest IP 1.3.0 and activated Activity Mod. After that, i uploaded the mps db update file and ran it sucessfull. Then, I uploaded all your pre-moded files and activated Activity Mod in includes/constant.php file. That's it.
Edited: I found 2 more:
1. adm/admin_mps_interests_info_type.php
around line 138
'S_XUITYPE_ACTION' => append_sid('admin_mps_interests_info_[color=red]ty[/color].' . PHP_EXT),
is it should be?
'S_XUITYPE_ACTION' => append_sid('admin_mps_interests_info_type.' . PHP_EXT),
2. ACP>>MPS>>Edit Interest Info: Can't edit it, when you hit "Edit", it gives an error message could find "admin_mps_interests_info_type.php".
The requested URL /adm/admin_mps_interests_info_type.phpmode=editxuitype&type_id=6&type='Heroes&type_type=0 was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
I could not figure it out  any help would be appreciate it
#10 Thu 23 Jul, 2009 19:02 |
This is a big mod... many users will appreciate this and will help in debugging.
Thanks for sharing and Good Luck.
#11 Thu 23 Jul, 2009 20:42 |
DWho
around line 138
is it should be?
thanks for pointing out those errors
I have fixed the problem you are having I missed one letter of code...
file is attached just copy it over the older one and I will updated the main download as soon as I can
Description: |
fixed admin file |
 Download |
Filename: |
admin_mps_interests_info_type.rar |
Filesize: |
3.21 KB |
Downloaded: |
260 Time(s) |
#12 Fri 24 Jul, 2009 12:57 |
pax
Tanks DWho! I have the Italian translate! Aspect fot the pro Silver IP theme...
#13 Fri 24 Jul, 2009 13:47 |
spydie
I´ll translate this when i got time for that.
At the moment i´ve got this F-1 Webtipp Mod in my to do list.
And that is a huge mod. Not the small one NewPlayer posted for .27
like i understand that´s the complete PhpBB3 mod with ticker, countdown and everything.
First adapt the mod to 1.3, check for failures and then translate it to spanish.
If i get tired of it i´ll give MSP a look and translate it quickly.
#14 Fri 24 Jul, 2009 13:57 |
DWho
Thanks but as I said there are nearly a hundred template files to recode for pro silver it is going to take an incredible amount of time... sadly I do not have a much free time to work on it...
so it will be a long while before I can do this...
Thanks spydie I appreciate that
oops also there is one small error in admin_mps_user_edit.php now fixed please copy attached file over to your site...
I have been checking links on the mod and as far as I can tell there should be no more problems thanks for reporting...
Description: |
 Download |
Filename: |
admin_mps_user_edit.rar |
Filesize: |
11.58 KB |
Downloaded: |
230 Time(s) |
#15 Fri 24 Jul, 2009 14:01 |
Page 1 of 4
