devildog
 Images In Posts
Greetings!
I know this topic has been cover many times, and after trying everything that I've found I tried.. At this point it's still not working right...
Here's my problem. When pictures are in posts, only the admin can see them. I've tried to view on Firefox, Safari and IE to avail. The gallery is visible to everyone, just not pictures, or smilies, in post. I'm suspecting some sort of permissions issue and for the life of me I can't figure out what it is. I've tried all the fixes in all the posts I've found here. Here is the link to my board.
Any help would be appreciated!
Thanks!
EDIT: This is the URL I'm getting when I right click on the smilie or picture: "http://thenortherntundra.com/h**p://thenortherntundra.com/files/thumbs/6/111220_0004.jpg" Could this be due to the rewrite in the .htaccess file? I get this on all browsers. On both the Mac and PC.
#1 Wed 21 Dec, 2011 16:48 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Images In Posts
Yes I noticed the same thing (the replaced tt/**) and have been searching to find an ACP setting that would cause it but could not find it (yet), Maybe someone that knows his way blindly across the Icy ACP can jump in?
The second domain is probably only added because h**p: is not an url (so this would automatically disapear when the tt/** is no longer replaced)
Please post the version number of your Icy installation and the (extra) content in your htaccess file (or simply temporary remove what is added in your htaccess and see what happens)
#2 Wed 21 Dec, 2011 20:10 |
devildog
 Re: Images In Posts
The version of Icy I am using is 1.3.24.77
The .htaccess is the one with the Icy distribution. Here it is:
#php_flag register_globals 0
#php_flag register_globals off
#php_flag magic_quotes_gpc on
#php_value memory_limit 16M
#Options +FollowSymlinks
# Disable the files listing feature
#Options All -Indexes
# Errors Pages - BEGIN #
# Decomment these lines to enable error document management.
# You can add absolute path if you want always the correct path being parsed.
# Something like:
# ErrorDocument 400 http://www.icyphoenix.com/errors.php?code=400
#ErrorDocument 400 /errors.php?code=400
#ErrorDocument 401 /errors.php?code=401
#ErrorDocument 403 /errors.php?code=403
#ErrorDocument 404 /errors.php?code=404
#ErrorDocument 500 /errors.php?code=500
# Errors Pages - END #
RewriteEngine On
#This may cause issues with subdirs and so it is not enabled by default.
#RewriteBase /
#Make sure the whole site goes to www.mysite.com instead of mysite.com. This is good for the search engines
#Edit and uncomment the below lines for your own site.
#Make sure to replace icyphoenix.com with your site address.
#RewriteCond %{HTTP_HOST} ^icyphoenix.com
#RewriteRule (.*) http://www.icyphoenix.com/>
#RewriteRule (.*) http://www.icyphoenix.com/$1 [R=301,L]< [R=301,L]
#Permanent redirection (the first line is the old domain, the second one is the new domain)
#RewriteCond %{HTTP_HOST} ^icyphoenix.com [NC]
#RewriteRule ^(.*)$ http://www.icyphoenix.com/>
#RewriteRule ^(.*)$ http://www.icyphoenix.com/$1 [R=301,L]< [R=301,L]
########## Rewrite rules to block out some common exploits - BEGIN
# Block out any script trying to set a mosConfig value through the URL
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## Rewrite rules to block out some common exploits - END
########## URL Rewrite - BEGIN
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*)-vp([0-9]*) ./viewtopic.php?f=>
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*)-vp([0-9]*) ./viewtopic.php?f=$1&t=$2&p=$3&%{QUERY_STRING} [L]<&t=
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*)-vp([0-9]*) ./viewtopic.php?f=$1&t=$2&p=$3&%{QUERY_STRING} [L]<&p=
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*)-vp([0-9]*) ./viewtopic.php?f=$1&t=$2&p=$3&%{QUERY_STRING} [L]&%{QUERY_STRING} [L]
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*) ./viewtopic.php?f=>
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*) ./viewtopic.php?f=$1&t=$2&%{QUERY_STRING} [L]<&t=
RewriteRule ^.+-vf([0-9]*)-vt([0-9]*) ./viewtopic.php?f=$1&t=$2&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-vf([0-9]*)-vp([0-9]*) ./viewtopic.php?f=>
RewriteRule ^.+-vf([0-9]*)-vp([0-9]*) ./viewtopic.php?f=$1&p=$2&%{QUERY_STRING} [L]<&p=
RewriteRule ^.+-vf([0-9]*)-vp([0-9]*) ./viewtopic.php?f=$1&p=$2&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-vc([0-9]*) ./forum.php?c=>
RewriteRule ^.+-vc([0-9]*) ./forum.php?c=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-vf([0-9]*) ./viewforum.php?f=>
RewriteRule ^.+-vf([0-9]*) ./viewforum.php?f=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-vt([0-9]*) ./viewtopic.php?t=>
RewriteRule ^.+-vt([0-9]*) ./viewtopic.php?t=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-vp([0-9]*) ./viewtopic.php?p=>
RewriteRule ^.+-vp([0-9]*) ./viewtopic.php?p=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-profile-u([0-9]*) ./profile.php?mode=viewprofile&u=>
RewriteRule ^.+-profile-u([0-9]*) ./profile.php?mode=viewprofile&u=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-ac([0-9]*) ./album_cat.php?cat_id=>
RewriteRule ^.+-ac([0-9]*) ./album_cat.php?cat_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-aspf([0-9]*) ./album_showpage.php?pic_id=>
RewriteRule ^.+-aspf([0-9]*) ./album_showpage.php?pic_id=$1&full=true&%{QUERY_STRING} [L]<&full=true&%{QUERY_STRING} [L]
RewriteRule ^.+-asp([0-9]*) ./album_showpage.php?pic_id=>
RewriteRule ^.+-asp([0-9]*) ./album_showpage.php?pic_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-aper([0-9]*) ./album_personal.php?user_id=>
RewriteRule ^.+-aper([0-9]*) ./album_personal.php?user_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-apic([0-9]*) ./album_pic.php?pic_id=>
RewriteRule ^.+-apic([0-9]*) ./album_pic.php?pic_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-apm([0-9]*) ./album_picm.php?pic_id=>
RewriteRule ^.+-apm([0-9]*) ./album_picm.php?pic_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-at([0-9]*) ./album_thumbnail.php?pic_id=>
RewriteRule ^.+-at([0-9]*) ./album_thumbnail.php?pic_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-dc([0-9]*) ./dload.php?action=category&cat_id=>
RewriteRule ^.+-dc([0-9]*) ./dload.php?action=category&cat_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-df([0-9]*) ./dload.php?action=file&file_id=>
RewriteRule ^.+-df([0-9]*) ./dload.php?action=file&file_id=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-kbc([0-9]*) ./kb.php?mode=cat&cat=>
RewriteRule ^.+-kbc([0-9]*) ./kb.php?mode=cat&cat=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-kba([0-9]*) ./kb.php?mode=article&k=>
RewriteRule ^.+-kba([0-9]*) ./kb.php?mode=article&k=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-kbsmp ./kb.php?mode=stats&stats=mostpopular&%{QUERY_STRING} [L]
RewriteRule ^.+-kbstr ./kb.php?mode=stats&stats=toprated&%{QUERY_STRING} [L]
RewriteRule ^.+-kbsl ./kb.php?mode=stats&stats=latest&%{QUERY_STRING} [L]
RewriteRule ^.+-pbc([0-9]*) ./kb.php?mode=cat&cat=>
RewriteRule ^.+-pbc([0-9]*) ./kb.php?mode=cat&cat=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-pa([0-9]*) ./kb.php?mode=article&k=>
RewriteRule ^.+-pa([0-9]*) ./kb.php?mode=article&k=$1&%{QUERY_STRING} [L]<&%{QUERY_STRING} [L]
RewriteRule ^.+-psmp ./kb.php?mode=stats&stats=mostpopular&%{QUERY_STRING} [L]
RewriteRule ^.+-pstr ./kb.php?mode=stats&stats=toprated&%{QUERY_STRING} [L]
RewriteRule ^.+-pbsl ./kb.php?mode=stats&stats=latest&%{QUERY_STRING} [L]
########## URL Rewrite - END
# Block if useragent and referer are unknown.
# the referer string can cause some problems with mozilla so it has been disabled
#RewriteCond %{HTTP_REFERER} ^.*$ [OR]
#RewriteCond %{HTTP_REFERER} ^-$ [OR]
RewriteCond %{HTTP_USER_AGENT} ^-$ [OR]
# You may want to enable these lines below to disallow php and perl scripts to access your site
#RewriteCond %{HTTP_USER_AGENT} ^.*PHP.*$ [OR]
RewriteCond %{HTTP_USER_AGENT} ^.*libwww-perl [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ^libwww.* [NC]
RewriteRule .* - [F,L]
#SetEnvIfNoCase User-Agent "^libwww-perl*" block_bad_bots
#Deny from env=block_bad_bots
### VIRUS - EXPLOITS - BEGIN
# SANTY
RewriteRule ^.*%27.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*%25.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*rush=.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*echr.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*esystem.*$ http://127.0.0.1/ [redirect,last]
RewriteRule ^.*wget.*$ http://127.0.0.1/ [redirect,last]
RewriteCond %{HTTP_COOKIE}% s:(.*):%22test1%22%3b
RewriteRule ^.*$ http://127.0.0.1/ [R,L]
# Prevent perl user agent (most often used by santy)
RewriteCond %{HTTP_USER_AGENT} ^lwp.* [NC]
# This ruleset is to "stop" stupid attempts to use MS IIS expolits on us
# NIMDA
RewriteCond %{REQUEST_URI} /(admin¦cmd¦httpodbc¦nsiislog¦root¦shell)\.(dll¦exe) [NC]
RewriteRule !(error\.php|robots\.txt) /error.php?mode=nimda [L,E=HTTP_USER_AGENT:NIMDA_EXPLOIT,T=application/x-httpd-cgi]
# CODERED
RewriteCond %{REQUEST_URI} /default\.(ida¦idq)$ [NC,OR]
RewriteCond %{REQUEST_URI} /.*\.printer$ [NC]
RewriteRule !(error\.php|robots\.txt) /error.php?mode=codered [L,E=HTTP_USER_AGENT:CODERED_EXPLOIT,T=application/x-httpd-cgi]
### VIRUS - EXPLOITS - END
# User-Agents with no privileges (mostly spambots/spybots/offline downloaders that ignore robots.txt)
# These bots are anoying website harvesting tools, webdownloaders, and a few misc annoyances.
# Bots ignoring robots.txt - BEGIN
#RewriteCond %{HTTP_USER_AGENT} ia_archiver [NC,OR]
### All bots removed to speed up things in htaccess...
# Bots ignoring robots.txt - END
# Rude Bots - BEGIN
# Rude Bots - END
# SPAM Referers - BEGIN
# SPAM Referers - END
# IE's "make available offline" mode
RewriteCond %{HTTP_USER_AGENT} MSIECrawler [OR]
# Various
RewriteCond %{REQUEST_URI} ^/(bin/|cgi/|cgi\-local/|cgi\-bin/|sumthin) [NC,OR]
RewriteCond %{THE_REQUEST} ^GET\ http [NC,OR]
RewriteCond %{REQUEST_METHOD}!^(GET|HEAD|POST) [NC,OR]
# Cyveillance is a spybot that scours the web for copyright violations and ?damaging information? on
# behalf of clients such as the RIAA and MPAA. Their robot spoofs its User-Agent to look like Internet
# Explorer, and it completely ignores robots.txt. So it has been banned it by IP address.
RewriteCond %{REMOTE_ADDR} ^63\.148\.99\.2(2[4-9]|[34][0-9]|5[0-5])$ [OR]
RewriteCond %{REMOTE_ADDR} ^63\.226\.3[34]\. [OR]
RewriteCond %{REMOTE_ADDR} ^63\.212\.171\.161$ [OR]
RewriteCond %{REMOTE_ADDR} ^65\.118\.41\.(19[2-9]|2[01][0-9]|22[0-3])$ [OR]
# NameProtect peddles their ?online brand monitoring? to unsuspecting and gullible companies
# looking for people to sue. Despite the claims on their robot information page, they do not
# respect robots.txt; in fact, they spoof their User-Agent in multiple ways to avoid detection.
# I have banned them by User-Agent and IP address.
RewriteCond %{REMOTE_ADDR} ^12\.148\.196\.(12[8-9]|1[3-9][0-9]|2[0-4][0-9]|25[0-5])$ [OR]
RewriteCond %{REMOTE_ADDR} ^12\.148\.209\.(19[2-9]|2[0-4][0-9]|25[0-5])$ [OR]
RewriteCond %{HTTP_USER_AGENT} ^NPBot [NC,OR]
# This ruleset is for formmail script abusers...
# We don't use Perl for Postnuke so this is not really needed.
RewriteCond %{REQUEST_URI} (mail.?form|form|form.?mail|mail|mailto)\.(cgi¦exe¦pl)$ [NC]
# Used to send these bots to someplace else you can change the url to whatever you would like
#RewriteRule .* http://www.microsoft.com/ [F,R,L]
#RewriteRule /* http://www.geocities.com/WestHollywood/Heights/3204/1home.html [L,R]
#RewriteRule !(errors\.php|robots\.txt) /errors.php?code=404 [L,E=HTTP_USER_AGENT:BAD_USER_AGENT]
#RewriteRule !(errors\.php|robots\.txt) /errors.php?code=404 [L,E=HTTP_USER_AGENT:FORMMAIL_EXPLOIT,T=application/x-httpd-cgi]
# This could also be used to simply deny access to your site instead of the one above
I just reinstalled it and restored the db with no luck.
#3 Wed 21 Dec, 2011 21:53 |
mort
 Spam Basher
 Re: Images In Posts
I believe your biggest problem is paths?
This is your url:
http://thenortherntundra.com/viewtopic.php?f=3&t=1
Icy Phoenix is/was not designed to run in the root of your domain, although it can be made to do so.
Can I suggest that you remove all Icy Phoenix stuff from the root of your domain and create a folder "forum" (Or whatever you wish it to be) and upload all of Icy Phoenix to that folder and install it from there; so that you end up with something like this.
http://thenortherntundra.com/MyFolderName/viewtopic.php?f=3&t=1
It's the simplest way of avoiding all other problems in the future, when it comes to path issues - And in particular - .htaccess issues.
#4 Thu 22 Dec, 2011 10:45 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Images In Posts
The problem is that an url is censored for guest reading if I understand correct Mort.
http and www are rewritten so the posted images won't show up for guests (http://www becomes h**p://***).
I expect an ACP setting for that but could not locate it, still can't
#5 Thu 22 Dec, 2011 12:39 |
devildog
 Re: Images In Posts
Mort: I'll give that a try and see if it works. Thanks for the suggestion!
Joshua: I looked for a setting in the ACP as well and could find nothing!
Thanks for your help guys! I'll report back with what I find.
#6 Thu 22 Dec, 2011 13:46 |
mort
 Spam Basher
 Re: Images In Posts
That's not what I was looking at.
There are double url's being generated to the image and nothing at all is showing in the post?
Firstly I suspect that the paths are not relative to the Domain and possibly include the unwanted http stuff etc.
So before it drives everyone mad trying to resolve it, I thought it would be a good idea to isolate Icy Phoenix to its own folder, and then tackle the problem.
Having Icy P in the root of the Public Folder - Has caused problems before.
@ devildog Please ensure that everything Icy Phoenix is uploaded in binary format and not ASCII.
#7 Thu 22 Dec, 2011 21:12 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Images In Posts
Sorry I seem to have been looking at an older version that did not have this feature included yet.
You should take a look at:
ACP >> Main Settings >> Posting And Messages >> Spam >> the 2 settings at the top take care of those url's for guests
**Side note: in the next beta release these settings will not influence smilies, it's waiting to be fixed!
If I look at your board now (in ip directory) I'ld say you need to clean your cache to make it look correct again
Thanks MG for your advice
Goodluck comparing,
...Joshua203
#8 Tue 27 Dec, 2011 13:39 |
mort
 Spam Basher
 Re: Images In Posts
I apologise too, because I missed this - "The version of Icy I am using is 1.3.24.77"
If I hadn't missed it I probably would have said nothing because I am in no position to support the Beta Releases of Icy Phoenix.
Either way - It's still not a good idea to splash Icy Phoenix files all over the root of the domain.
#9 Tue 27 Dec, 2011 22:53 |
spydie
 Re: Images In Posts
was´nt there a setting in ACP, that users under xxx posts can´t set an Avatar or link in the signature ??
____________ Out of Order
#10 Wed 28 Dec, 2011 11:47 |
Joshua203
Joshua 203
Dutch A Go Go
 Re: Images In Posts
Yes , as pointed out in post 8
EDIT:
Not for avatar though but that would be quite pointless IMHO
EDIT2:
this topic has been split to keep it on topic, the moved posts are here:
http://www.icyphoenix.com/viewtopic.php?p=54848#p54848
#11 Wed 28 Dec, 2011 13:09 |
TannaLDietrich
Tanna dietrich
 Re: Images In Posts
Everyone wants to add Image to post and look is good. I think you have clicked on a hidden button. So You can check and uncheck to it Ricoh printer support
#12 Thu 14 Jun, 2018 22:13 |
