Tags And Keywordsicy phoenix, patch
Post Icy Phoenix 1.3.0.53a - Patch
PATCH REPLACED BY PATCH FOR 1.3.0.53b
______________
Hi all,
here is the first patch of Icy Phoenix 1.3.0.53 which will upgrade your version to 1.3.0.53a.
How to install this patch:
  1. Make a full backup, both files and DB
  2. Download the patch from the link below
  3. Extract the package on your hard disk
  4. Copy the install folder in the root of your website
  5. Launch install/database_update.php
  6. Upload all files into your website by replacing old ones (please note that you may have customized some files like constants.php or lang_main_settings.php, and you may want to update them before uploading)
  7. Enjoy your updated website!
Not Authorized
You are not authorized to download this file
Should you have any kind of error, please use the support forum to report it..
Post Re: Icy Phoenix 1.3.0.53a - Patch
First ;-).
Thanks !
are there any changes between this and the RC patch?
Play Games at GamesCampus!
Only few changes... but I have not traced them down. Best is going through WinMerge.
Thanks Luca...
Updated all  my sites with this patch... working well
Hi All there!
Just a simple (stupid maybe) question. I have this versión of Icy Phoenix: 1.2.0.27c
Can I update to "Icy Phoenix 1.3.0.53a" doing this steps? Or I have to do something first?
Steps:
- Make a full backup, both files and DB
- Download the patch from the link below
- Extract the package on your hard disk
- Copy the install folder in the root of your website
- Launch install/database_update.php
- Upload all files into your website by replacing old ones (please note that you may have customized some files like constants.php or lang_main_settings.php, and you may want to update them before uploading)
ialvarezSend private messageVisit poster's website
You´ve got to download the full version of 1.3.0.53a.
no way to update only using the patch.
when follow the upgrade instructions that come with the pack
